Results 1 to 3 of 3
Thread: ATC vs TRX 250R brake pedal
    May 2005
    Southern NH
    1,489
    Question ATC vs TRX 250R brake pedal
    Hey guys,
    So I'm finally throwing my 85R back together and I had purchased an ESR rear brake pedal. But then I noticed this ESR TRX version does not have the shaft welded on to it like my 85R one did. Upon checking the parts fiche, I realized this was how they were built OEM...
    So, has anyone else found a way to overcome this issue? Finding a smooth shaft would be simple, but it has splines on the end which have to line up with the brake push arm that attaches to the master cylinder, so that makes things more tricky. I figured I cannot be the first one with this issue!
    http://www.eddie-sanders-racing.com/...ke%20pedal.htm
    Thanks in advance guys!
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Jun 2003
    englishtown NJ
    2,676
    trx and atc brake pedals, brake linkage and master cylinders are totally different. No way you can make it work, without alot of work.
    May 2005
    Southern NH
    1,489
    Well live and learn I suppose!
    It would seem that if I could just get a proper length shaft with splines I will be all set. I will have to stop by the local machine shop and see if they can make one for me.
