Results 1 to 15 of 25
Thread: 84 Tecate Woes
    Des Moines, IA
    1,303
    84 Tecate Woes
    I finally got my Tecate back together after several months of apartedness (I just made up a new word...the state of a project where you know it's in pieces, but you can't remember where you were) and after a re-chromed cylinder, new piston and rings, it now starts on the first kick. That part is awesome. Unfortunately, the machine's annoying tendency to run for a few minutes and then just abruptly quit remains. In fact, I think it's worse! Took it out for 5 minutes and it suddenly died. It wouldn't start again an hour later either, so we towed it home. Next day it started right up again.
    Something about that makes me think bad coil. I admit I haven't had the opportunity to actually check for lack of spark when it fails, because it seems like every time it happens, I'm just far enough away from my tools to be inconvenient! Anyone had this issue? I know how hard these things are to troubleshoot from just a description, but I thought if someone else said "Oh yeah, I've replaced 3 coils or CDIs on those over the years", that's what I'd try first.
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    NEPA
    7,049
    Have you pulled the flywheel to make sure it is a one piece? If it's still 4 magnets,replace it with a Swinehart encapsulated flywheel. He will exchange for your old one. Check your stator coils ohms. That is most likely your problem. But yes, you will have to get a LOT more information,from a google search,and to give to us for further dx.I personally would not start it again until you know you have a solid flywheel in there. Then, make it die and check for spark.
    Des Moines, IA
    1,303
    Quote Originally Posted by atc007 View Post
    The original stator torpedoed a few years back, so it's got a Ricky Stator in it....but the flywheel is OEM.
    Not a bad idea...what does John charge for those?
    When mine did that the stator was bad.
    Wichita, Kansas
    1,359
    Sounds like you are in the same boat as me. It was acting the and yours. Turns out after 2 oem stators, rewinding several of my own stators, buying Ricky's stator, 2 flywheels, then 3 ignition coils, and a handful of plugd. It was the cdi.
    Ohm out the stator. Ohm out or replace he ignition coil and plug. Check the magnetism on the flywheel with a screwdriver. The magnets should all stick decently well.
    cochran is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2011
    Bemidji, MN
    305
    What Fab said.
    Wichita, Kansas
    1,359
    The stators are a common part to go on these. Take the multimeter to it, it should be within spec for the book.
    I've played with several of he stators, everyone I got my hand on was on the lower side of he resistance for the books tolerance. I've wrapped extra wire on the source coil(the big one). That helped out for a bit, but ultimately failed.
    If your into diy and want to wind your own stator.. the Tecate likes 33-34g magnet wire. Use a drill to do the winding and a coffee stir to guide the wire.
    On of these days I'll make a video. It's to simple and cheap. Over winding the source coil=hotter spark.
    Des Moines, IA
    1,303
    Well, I took some measurements of stator windings, ignition coil, and CDI, so I have a baseline. Tomorrow I will take it out and ride until it fails then take measurements again, and see if I can find the culprit.
    Wichita, Kansas
    1,359
    What are your measurements?
    Sep 2006
    Northwest Indiana
    1,893
    Sounds like a CDI. Years back we had one that did the exact thing thing.
    Des Moines, IA
    1,303
    Quote Originally Posted by RubberSalt View Post
    Here's the measurements. I spoke them to Evernote, so forgive me if the wording is strange:
    Electrical measurements taken with Craftsman digital multimeter. On 200 ohm range multimeter gives a .3 ohm short measurement of cables only.
    Ignition coil primary winding is .7 ohms
    Ignition coil secondary winding taken on 20K ohm range measures 5.87 K ohms
    Stator measurements
    Red to Black measured on 2000 ohm Range measurement is 205 ohms
    Red to blue measures 25 ohms
    Black to blue measures 180 ohms
    Measurements of CDI / ignition module
    Red / yellow to Black 1.488 megohms. This is measured on the 2000k ohms scale.
    Negative probe is on red / yellow positive probe is on black.
    Blue to Black measurement is 237 K ohms
    Negative probe is on Blue, positive probe is on black
    BTW, work is kicking my ass, so I haven't had time to actually ride it and take measurements after failure yet.
    Wichita, Kansas
    1,359
    Black and Blue looks weak. Do you have another source coil? Getting this to 195 ohm+ will probably take care of your troubles. The manual says 170, this is way to low.
    This is what I'm thinking.
    Odds are that the wire's enamel coating is burnt up somewhere deep inside the coil. When it heats up further, it expands and shorts out to ground, which is fine on this coil. At this point, little or not enough current is being produced, hence, no fire.
    I've found ignition coils from Ricky Stator for $53.
    If you don't mind soldering and winding your own coils, you can do it for much much less. The OEM coils use 34g wire, but 33 works as good, if not better. It also provides more life(because 30 years is not enough lol).With 33g, you can stuff about 1100ft of wire on these. It gives for a nice hot spark.
    Simply remove the old wire, wrap the iron in tape, wrap wire around the tape(leave a piece sticking out so you can solder to it later). Use a drill to spin the Iron and use a coffee stirr or straw to guide the wire as it turns. Once the prep work is done, it takes just a few minutes to turn 1000 feet of wire. scratch the side of the wire and measure the resistance between the piece sticking out and the scratched part. Keep winding until you get plenty of wire on there. Over stuffing:These will touch the inside of the flywheel before the outside, sooo.. yea.
    Heres some $9 33g wire. http://www.ebay.com/itm/33-AWG-Gauge...RgPAVz0qqHellg
    The trigger coil is a much lower voltage/current producing coil. It has a narrower range for resistance and needs to stay within the 20-30 ohm range when using 34g wire. For 33g wire, that changes to 16.5-24.5 ohms.
    Des Moines, IA
    1,303
    I don't have another coil. I bought this Ricky Stator new about 2 years ago and the machine has had about an hour on it since, so I don't WANT to believe it's that. However, I've since heard here on 3WW that a fair amount of people have had trouble with Ricky Stators. If it does turn out to be that, at least I can replace just the one coil. When I bought the complete stator and plate a couple years ago it was about $125.
    While I am a bit of an electronics nerd, I probably won't wind my own unless it's absolutely necessary.
    So I guess next is to run it, try to get it to fail, and see if I can see a change in the resistance reading. Might be a couple days to get back to it.
    Wichita, Kansas
    1,359
    Come to think of it, I never checked the resistance of my new stator. I picked up the Ricky Stator for $125 some time ago. If i get some time, I'mma ohm it out and see what I get.
    It's possible that they are using the 33g wire opposed to the 34. If that's the case, the lower resistance should be ok.
    If all else fails, Send me the coil or the Stator, and I'll rewind it at no cost. I've got plenty of wire sitting around not being used. I've also managed to fit a YT125/175 source coil into these, had to slot the bolt holes on the coil about a 1mm, but it fit.
    I think I'm going to 3d print a jig so quickly prep these and wind them.
    Wichita, Kansas
    1,359
    I shall print these tonight!
Name:	Coil winder.JPG
Name:	Coil winder 2.JPG
Name:	coil winder 3.JPG
    should make chucking the iron into a drill much easier.
