Thread: Reverse troubles on 200es
    Aug 2016
    texas
    Hi I just picked up a 1984 big red 200es yesterday and it was in good condition cosmetically speaking but with a little tinkering I got the motor running. Well anyways my big red will not switch into reverse. It won't budge at all. What could be the problem?
    Jun 2016
    Klamath County, OR
    15
    Have you changed the oil? Cleaned the filter rotor? Done basic start-up maintenance (chain lube/brakes/fuel tank clean)? PLEASE do this before anything else regardless of previous maintenance record, you'll thank yourself later if you take care of the basic stuff right off the bat. (you can find a list of ATC manuals here: http://www.oscarmayer.net/atc/manuals/, it has service tables for ya.)
    It should only be shifted into Reverse from neutral position. Refer to this thread: http://www.3wheelerworld.com/showthr...-200es-reverse
    If prev. owner let it sit for a long time without running it, the shifter could also be frozen up from lack of usage. Does it go into high and low properly, but won't go into reverse? Or is the lever stuck completely?
    Aug 2016
    texas
    Well I figured out that its not reverse all the way down its at the very top lol. Ive never seen a machine were the gears shift down instead of up. thanks for the help though!
    Jun 2016
    Klamath County, OR
    15
    That was easy! Glad you got it fixed. Sometimes the simplest fixes are just user error.
    Aug 2016
    Phoenix, Arizona
    11
    Glad you figured it out these are fun Bikes!
