This is a new issue for me. I'm working on a 350rancher that the clutch sticks. I adjusted past tight and went out and drove it around with the lever held up untill it broke loose and slipped like it supost to, and then adjusted it and it worked like a new one ( this is a really low hour bike with like new oem tires)untill you let it sit for 20min or so the it sticks again untill you ride it around in 3rd with the shifter up untill it brakes loose then it ok untill you leave it sit for awhile. Like I said before the bike sits alot in a heated garage and is babyed that why it was stuck in the first place. But I never had one restick it self this easy. Anybody else run into this issue?
