Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Genuine vs. OEM
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Genuine vs. OEM
    What is the difference between genuine jets and OEM EQUIVALENT jets?
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Leevvii's Avatar
    Leevvii is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2016
    Australia
    216
    EDIT [im a ] thanks matt
    it gets misused alot on ebay and the likes, to mean an original part [not always new or genuine], but on that bike since the seller owned it
    n
    Mar 2003
    Australia
    1,919
    No OEM means, Original Equipment Maunfacturer. I.E Honda, Yamaha, Suzuki, Kawasaki etc.
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by atcmatt View Post
    You're half right. OEM does mean original equipment manufacturer. Original equipment manufacturer is any company that manufactures original stock parts for any particular brand. Such as keihin, mikuni, shindy, showa, nissin, ask, etc.
    Slidell, LA
    4,738
    Quote Originally Posted by AK47KID View Post
    Headaches. spend the extra 2$ and get genuine.
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    Jets? Really!? Buying aftermarket jets wI'll cause headaches? I really worry about you guys sometimes.....
    Atc 500x for the win! (Hopefully.... one day)
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by plevib View Post
    Yes , really. It's called experience. You should try it sometime.
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Yup I'm sure that you've experienced loads of problems from all of the many brands of jets that you've tried. I guess keihin and mikuni are the only companies with a clue. You're probably right. I'm going to go buy and trike and meticulously and restore it with all eom parts and look at it in my living room so I can get some experience. Because lord knows the only way to know anything is to do it exactly as the 3ww crew would
    Wichita, Kansas
    1,361
    I've never had a problem with Aftermarket jets. I've never used aftermarket jets. <-- i know better lol
    I solder/drill oem jets. After finding the size that works best. I buy the OEM jet that matches. I do own a partial jet kit that covers most sizes I use or need to jet with. 170-330 with Mikunis, 150-180 with Keihin.
    It's very cheap, and simple to modify them. Get a microdrill bit set, solder the jet up, drill it out. You can find cross references for jet sizes and holes for each manufacture out there. If you have a part store out there close by (lucky me!) Just take the bit and find the jet it fits.
    Never had a problem with this method. It's cheap. It works. It saves driving back and forth trying to source jets.
    Wichita, Kansas
    1,361
    I dunno bout that, I wreck .
    Ask the old timers about my early days and my arc welded pipe I made for my YT175. It ran, but it was uglier than the toothless meth head grandma behind the k mart down south.
    Oct 2013
    Wherever I May Roam
    3,757
    Yep. $2 is not worth having to wait for another order of jets to come when the cheap aftermarket jets aren't sized correctly. Some of us do this stuff more than others. Also, some of us get dealer prices on OEM, so we don't need to waste time with cheap jets.
    Soutwestern PA
    2,040
    In this case, Genuine means Keihin brand.
    Yes, he should buy the Keihin jets to put in his Keihin carb.
    9 times out of 10 'OEM equivalent' means 'Chinese knockoff.'
    In some cases, that's good enough.
    In this case, stick with the name brand.
    plevib's Avatar
    Dec 2015
    North Dakota, USA
    358
    Man I wish I was "some of us". Your life sounds awesome!
    Oct 2013
    Wherever I May Roam
    3,757
    easy there, trigger
    frankydodo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2014
    Quebec, Canada
    170
    You should buy my 200x. Because i can't even put a honda cam in it, thats what i've been told here
