Results 1 to 7 of 7
Thread: 1985 125m starter issue
    Apr 2016
    Manitoba
    60
    I'm pretty sure it must be the starter because what's happening is the starter relay is making a ticking noise whenever I go to start and I've tried two relays both of which I know work, is there anything else it could be? And is it hard to change a starter on this trike?
    Oct 2013
    Wherever I May Roam
    3,757
    Did you charge and test your battery?
    Apr 2016
    Manitoba
    60
    I'm charging it right now to make sure, it's a pretty new battery though I'll get back with the results
    Oct 2013
    Wherever I May Roam
    3,757
    Sounds good.
    If you determine that your battery is good, and your are SURE your solenoids are tested and proven, then you might go the route of a starter rebuild kit. They're fairly simple to rebuild, especially if you post a thread and ask for help
    Here's a kit for the 84-85 125m. http://www.ebay.com/itm/Honda-ATC125...hVCXZd&vxp=mtr
    Apr 2016
    Manitoba
    60
    And also after I try to start it the head light and neutral light turn off for a bit, could this mean a loose connection?
    Oct 2013
    Wherever I May Roam
    3,757
    .....yes... It could also mean the starter is shorting. Check and clean all connections, especially grounds.
    Apr 2016
    Manitoba
    60
    Ok and I fully charged the battery, same thing I'll look into a rebuild kit, thanks!
