Thread: 1986/1987 Kawasaki Tecate headlight/tail light wiring diagram
    Nov 2010
    Auburn, NH
    1,061
    Hello everyone,
    Would anyone happen to know where I can obtain a wiring diagram for both the headlight and tail light for an 86/87 Kawasaki Tecate?
    I have almost all of the pieces with the exception of the headlight bracket that mounts on the forks and rear tail light.
    Any information would be much appreciated.
    Thank you,
    IronBear
    Trikes Currently Owned
    ~1985 Honda Big Red 250ES ATC
    ~1986 Honda 250SX ATC
    Sep 2005
    MICHIGAN
    2,027
    86 T3
    84 T3
    86 KX250
    Nov 2010
    Auburn, NH
    1,061
    Thank you nd4speed!
    Nov 2010
    Auburn, NH
    1,061
    I think the previous owner changed the exciter coil because there is only three wires coming out of it instead of four. I'm missing the yellow wire that supposed to go to the light switch but have yet to pull off the cover to inspect it.
    I'm going to remove the cover tonight and take some pictures, then post them to this thread.
    So if that's the case, where can I get an exciter coil that has the lighting coil, or should I say a stock one?
    Thanks
    Sep 2005
    MICHIGAN
    2,027
    86 T3
    84 T3
    86 KX250
    Nov 2010
    Auburn, NH
    1,061
    Thank you nd4speed!
