A few weeks ago i posted about a flickering problem i had with my leds hooked directly to my stock headlight harness, in that thread i ask about adding a capacitor to help the problem, and was advised to convert to dc and use a regulator/ rectifier. The install is finished and works to satisfaction, although the time invested was vastly more than expected. All connections were soldier and heat shrinked and electrical tape in some places. Black plastic loom was used over wire for a neater appearance. In all my research on the mod i could find no pictures of the installs and this is mainly why i'm posting this thread. Positive comments and advice is more than welcome, just trying to help anybody thinking of going this route.
Components
Stock stator factory ground unsoldiered and external wire added to make a floating ground
1984 atc125m regulator
1989 chevy truck terminal block used for power distribution cut in half (junkyard)
Sigmastek St7zs battery
Led light bar and pods total wattage 108w stator output is 159w
radio shack 3amp diode to have factory hi beam switch power both lights
