Results 1 to 14 of 14
Thread: 200ES BIG RED - Painting the gas tank and forks with base/clear
    Dec 2015
    Allegany County NY
    29
    Currently restoring a 1984 Honda BIG RED 200ES. When it came to the tank and the forks I had a hard time finding the Honda passion red. I found an automotive paint for a Nissan that worked out well for me. I first used Redkote to coat the tank. Then I went on to stripping the parts, bodywork, painting with base, then clear. After that it was on to color sanding and buffing and finally add the decals. Click image for larger version.
ID:	234265Click image for larger version.
ID:	234266Click image for larger version.
ID:	234267Click image for larger version.
ID:	234268Click image for larger version.
ID:	234269Click image for larger version.
ID:	234270Click image for larger version.
ID:	234271Click image for larger version.
ID:	234272Click image for larger version.
ID:	234273Click image for larger version.
ID:	234274Click image for larger version.
ID:	234275Click image for larger version.
    NEPA
    7,051
    Very nice work Mark. Thanx for sharing!
    Dec 2015
    Louisiana USA
    30
    Any automotive commercial paint store can mix Honda Passion Red.
    Jun 2015
    stonecreek ohio usa
    654
    Man! That's as fancy as can be. Nice work
    Oct 2013
    Wherever I May Roam
    3,757
    Looks better than new, great job.
    Jul 2016
    Kentucky
    61
    That tanks looks great! What's the best way to clean the inside? I've got a few so full of rust and gunk I don't know how to get it squeaky inside. Especially the way the caps are flanged inward.
    Jun 2015
    stonecreek ohio usa
    654
    Some guys on the trikesylvania forum's are saying apple vinegar and some other stuff. Check it out
    Dec 2015
    Allegany County NY
    29
    I have used white vinegar to clean the inside of the tanks with good results. You may need to let it soak for a few days on a heavily rusted tank.
    Feb 2016
    Stellenbosch, South Africa
    192
    Wow nice job!
    @HoldMyBeer ... pool acid will clean up the rust in a few minutes, some folks will say don't do it, but I have used it on over 15 tanks and always had good results.
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    RamsesRibb's Avatar
    RamsesRibb is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Louisiana
    316
    Let me ask a question due to my lack experience. When you sanded and filled the dents i noticed a good bit of left over paint near the cap and bracket. Did you sand off the rest of the paint after filling the dents? Or did you just paint over it?
    Did you sand blast or some other technique?
    Sorry if this is basic or common knowledge but I have previously used local services for blasting and want to just do it myself if possible.
    Previously known as HighFlying101 since 2003
    I changed my email and lost my password
    Current: '85 Tri-Z , '83 250r , '86 Tecate, '80 ATC110
    Prior: '85 FTZ ATC350X, '85 Tri-Z, '85 ATC200X w/ Bassani exhaust, '83 Big Red, '81 ATC185S, '79 ATC110
    http://www.ipetitions.com/petition/tpctrikes/
    Dec 2015
    Allegany County NY
    29
    I did not remove all of the paint after filling the dents. This was just a practice job for me since I was not sure of the color match. I typically use a chemical paint stripper then I media blast the tank in my blast cabinet. In my experience using the chemical stripper saves a lot of time as compared to just media blasting the tank. Now that I know I have a good color match I would completely remove all the paint from the tank before I do any bodywork and primer for future jobs.
    May 2016
    San Antonio, Texas
    21
    That red looks good. I have found rustoleum "sunrise red" 7762 is a pretty good match with Honda red.
    Dec 2012
    812
    Wow...that tank looks better than they did on the showroom floor! Thank you for sharing.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    That is really nice work.
