Hey guys,
A buddy of mine went to the local ATV park here and rolled his Honda 250sx into a 5' hole of water. He said the bike was still running when it rolled into the water, but shut off soon after. The bike sat in the water for about 30 mins before he was able to get someone to pull it out of the water. After getting it out of the water and checking the cosmetic damage to it, he checked the oil and there was water in the oil.
After taking the bike home and washing it off, he checked the air box and it was completely dry. He also checked the top of the carb and said there was no moisture there as well. He did not check the jets in the carb, but drained the gas after getting it out of the water. He then drained/replaced all fluids (motor oil, gas and diff oil) and checked the spark plug, which was dry. He then tried to start it using the electric start and nothing happened. However, the headlight will turn on and the high/low beam works. He tried kick starting it, but the engine wouldn't start either. He said it seemed to turn over as normal when attempting to kick start it.
Now for my question. I realize there could be any number of issues after being submerged in water, but based on everything I described above, what would you all recommend to be some things to check first? I have a spare CDI box we're gonna try tomorrow and I'll also clean the carb. However, what are some other things that might be the issue based on this scenario?
Thanks in advance for any help you might be able to provide.
