Results 1 to 2 of 2
Thread: trailer hitch on YTM225DXL
    Aug 2016
    Stephenville, TX
    18
    I am rebuilding a YTM225 and plan to pull a medium trailer to haul pasture manure to a central compost pile.
    I plan to use a common 2" hitch ball on the rear swingarm/axle housing, but it doesn't look as cut & dried
    as on my Big Bear 350!
    Can someone recommend a working mount? I anticipate a 1/2" thick mount to receive the ball, but not sure
    where to fasten it nor what it would look like. Pictures of your working mount would be helpful.
    I have most all the machinery to easily fabricate/drill/weld steel, but prefer NOT to weld directly to axle housing.
    I CAN weld it to the tri-moto, within the next month or so, as I will be dismantling the rear end to rebuild it.
    Seems strange there is no recognizable hitch provision, as the factory dealer videos on UTube depict these trikes
    pulling different farm implements/trailers!
    Thanks in advance for any info you may provide.
    John in Texas
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    There is a three bolt holes on the swingarm, two that hold the skid plate on and one above those. That's where mine is mounted. It was an aftermarket hitch setup in the day.
