I need a rear bearing carrier used or new.
also what other models and years carrier will fit?
thanks!
thanks!
is your carrier cracked that you think you need a new one? bearings and seals are all over ebay
I bought it without the carrier. So I don't have one. all the ones I have found have been mostly chipped off on one side.
you can covert it over to 300ex its not much different and $80 shipped get ya a dual row billet one. bearing ID and OD is the same from what i remember but you'd have to just go to partzilla.com and look at the bearing sizes to double check. There was a company selling billet dual row 200x ones for like $250 at one point. guys swap 2nd gen R axles in 200x so the carriers are about the same.
from what i measured on the 86 one I had vs a 300ex one was like 1/8" different or so. Any smart person can put some spacer shims in and call it a day.
http://www.3wheelerworld.com/showthr...R-G-FORCE-AXLE
mike over at www.hreatv.com has a 86-87 200x swinger he made for a guy that was all 300ex at the back. i almost used it on one of my bike but didnt. it is still there and i know he will sell it if you want to just covert everything plug and play...if not id start collecting used 300ex stuff since its dirt cheap and will work in your swinger. i run 300ex axle in my 1st gen 200x...thats way harder then just swaping out carriers but mine I made mine a bolt in anyway with a few mods.
A company called NICHE makes loaded carriers for our old trikes....
