Results 1 to 11 of 11
Thread: How much diff fluid do you put In 85 250sx?
    Apr 2016
    Manitoba
    60
    As the title says, thank you!
    Nov 2010
    Oshawa, On, Canada
    2,123
    Manual calls for 100cc's. I normally jack the rear end up a bit and put more in. Just make sure your vent is not clogged.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Apr 2016
    Manitoba
    60
    Thank you!
    NEPA
    7,051
    Level with bottom of fill hole,tilt to the right a tad maybe. But you don't want much more in there.
    Apr 2016
    Manitoba
    60
    Where is the vent?
    Apr 2016
    Manitoba
    60
    ok so I got a few questions, when I drained the old stuff out it looked like chocolate pudding, could this be responsible for causing clunking noises? And the diff seems to not be taking any oil I put a drop in and it's flowing out the fill hole??
    Feb 2013
    Senoia, Ga
    635
    If it looks like pudding, then its more than likely been exposed to water at some point.
    I would flush it out real good, before doing a refill.
    Oct 2013
    Wherever I May Roam
    3,757
    Excessive noise is caused by wear, it is a mechanical issue and therefore must be inspected and addressed mechanically.
    NEPA
    7,051
    Quote Originally Posted by Dawsman View Post
    Your diff needs rebuilt. It will have to come out and come apart for new bearings/seals and most likely a pinion shaft. There are some specific threads if you want to look them up
    Apr 2016
    Manitoba
    60
    Ok great thanks for the help!
    Mar 2003
    Australia
    1,919
    FlyinW is the man for diff rebuilds I hear!
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
