Thread: 84 300r led conversion
    Apr 2016
    san diego
    18
    Im trying to set up some leds on my 84 300r build. Im trying to run a rectifier off of a trx200sx its a 5 wire 2 yellows 1 red 1 black 1 green. Im going to run a battery to help . Anyone have a wiring diagram for a trx200sx? Or a similar 5 wire rectifier diagram? Thanks
    Blossvale NY
    4,563
    I don't have the answers you are looking for, but don't LED lights draw significantly less power than incandescent halogens??? Or is the problem that LED lights don't take to the varying voltage of your original electrical system?
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    You have the right idea of using a rectifier to convert your ac unregulated voltage to regulated dc voltage. To use your rectifier correctly, you need a floating ground coming from your stator.
    I have written a walk through on this process pertaining specifically to a 350x but the overall process is the same.
    https://lookaside.fbsbx.com/file/Hon...gnR6IqMY7g9nQQ
    Let me know if the link doesn't work, I'm attempting to do this from my phone. If it doesn't work, send me a pm with your email address and I'll email the file to you.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Aug 2016
    East of Worcester ma
    1,373
    Maybe this will help?Click image for larger version.
    TwiZ's Avatar
    TwiZ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2015
    Elk county Pa.
    187
    If you have only two wires coming out of the stators what i did was isolate the grounds for the lights and just used the ground from the battery. I used one of the cheap rectifiers on sleazebay for like $5. I did this on my 200x,made a lil battery box and wired up recifier,i just had to make sure the ground was isolated from the rest of the bike, not grounded to the frame anywhere,used the battery ground. The two yellows should come from the stator,red to charge battery black to lights green to ground if my memory is correct. When you say 300r is that a 250r punched?
    1984 Honda 200X
    1984 Honda 200S Bonecrusher
    1975 Jeep CJ5
