Results 1 to 15 of 17
Thread: 82 250R low compression
    Sep 2016
    Las Vegas
    9
    Hi all,
    I bought a decent looking 250R a few weeks ago. When I got it, it wasn't running, low compression. The guy I bought it from was running the Dunes and it just slowed down and shut off. I took it home and pulled the top end. Rings were welded to the piston and there was some wear. I took it to the shop and they bored .20 over and I got a new wisco piston and rings. I took it home and put it back together, but still low compression, about 60psi after 5 kicks. I would get a pretty strong pop through the exaust, enough to blow papers off of my bench 6 feet away. I took it apart again, checked the rod, no up and down play, and very minimal side to side. I did notice the top gasket was wet all the way through and the bottom was slightly too. My reeds looked fine and sealed. the carb has been taken apart and cleaned. I do not know a ton about 2 strokes, so I am appreciative for any knowledge lent. The new piston doesn't seem to have any play, but I am used to the rings sticking out from the piston more than they do, they look almost flush. I torqued the heads down to 22lbs, maybe I should have went more?
    Last edited by Hrobertson1; 09-26-2016 at 10:46 PM. Reason: additional information
    Slidell, LA
    4,738
    The shop matched the piston to the bore? Did you install the piston with the arrow towards to exhaust port and the numbers on the rings facing up?
    Sep 2016
    Las Vegas
    9
    Thanks for the reply! The shop (Mikes Moto) told me the piston was matched to the bore. I did not see any marks on the rings, and the instructions in the box said they could be installed any way. I did notice after putting the rings on that I had to turn them to get them to seat flush.
    Slidell, LA
    4,738
    They can be installed either way if there are no numbers. Are you 100% sure yours didn't have numbers? Also did the piston get installed with arrow facing exhaust port? The reason you had to turn the rings is because of the ring alignment dowels. On a fresh bore your static compression will be a little lower than spec due to rings not fully sealing. 60 lbs is really low for a new set of rings. When you performed the compression test did you hold the throttle wide open and kick until the needle stopped moving...it may take more than 5 kicks. If that all checks out you may have a head leak. I would advise performing a pressure test to see if you have any leaks. Look up pressure test in the search function, upper right hand corner.
    Sep 2016
    Las Vegas
    9
    Thanks for the info Yes, I made sure the arrow was pointing to the exhaust port. I looked over the rings a few times thinking there would be a number or letter, then I opened the instructions and read they go in any way. I did hold the throttle all the way open, and seemed to get less compression than with it closed. I am going to clean it up and put it back together tomorrow and put another 5lbs on the torque and see if it will seal. I will run it through a pressure test if I can put together one from the searches.
    Sep 2016
    Las Vegas
    9
    So I got a leak down tester and other than a small leak at the reed gasket it held 8lbs for the 4 hours I had it hooked up. So should I tell the machine shop that did my bore, piston and rings are not right?
    Slidell, LA
    4,738
    I would think that something is wrong with the bore. Do you notice any scratch marks or any wear on the four corners of the cylinder? Also, did the machine shop camfer the ports (cut a bevel on the port openings)?
    Sep 2016
    Las Vegas
    9
    I don't see any wear marks. I also noticed when I took it apart there was a think layer of oil on the cylinder wall. Shouldn't the rings scrape most off?
    Thanks for helping me out
    Slidell, LA
    4,738
    Quote Originally Posted by Hrobertson1 View Post
    Yeah, the cylinder should be fairly clean. This is odd. Have you checked the ring gap by putting the rings in the bore and putting a feeler gauge in the gap? Do this and compare to manual specs.
    Are the ports chamfered?
    Sep 2016
    Las Vegas
    9
    Yea, I am pretty sure its the rings. I took them off to check gap in the cylinder, and they dropped right thru the bore. I am worried about taking it back to the shop, they keep insisting it cant be the bore, and its the bottom end seals.
    Slidell, LA
    4,738
    Best advice I can give you is to call, chat and then send the cylinder to either of the people below and let them get the right parts for you.
    http://farmandsandtoys.com/ocart2/index.php (jeff is the owner)
    http://www.smallenginemachineworks.com/ (john tice is the owner)
    Carthage NY 250r rules
    2,355
    The rings should not drop right threw the cylinder.Check your piston to cylinder clearance should be .002-.004 thousands.Bad or leaking crank seals wouldnt have much of an effect on the compression.
    250r rules
    Aug 2015
    Portland Oregon
    174
    You’re getting good advice from everyone so far.
    Did you check the end gap in the rings? Wiesco has at times put the wrong ring sets in the box. Generally speaking the ring end gap should be .003-.004” per inch of bore diameter.
    Is your new cylinder bore job round & straight? The skirt clearance for forged Wiesco pistons is printed on the box; Wiesco piston requires a .002” skirt clearance for a 250cc cylinder,
    This type of hone mandrel is our ultimate for small engine cylinders.
    Many shops use a ball hone for finishing cylinders. Ball hones are great to deburr & champher your ports; but not much more. Other shops use a break cylinder hone. (Egg Beater)
    Break cylinder hones have a tendency to snag in ports when in the BDC area of the cylinder on 2 stroke cylinders.
    If your machine shop used an incorrect method of finish honing, the piston may catch the cylinder wall in the BTC area around the transfer port cut outs. We always slide the new piston up & down the finished bore while finish rinsing the bore.
    Our finish hone mandrels use a 280 or finer grit stone set. If everything measures out correctly on the cylinder, you’re maximum cranking compression should show up almost immediately.
    John Tice
    503-593-2908 Alternate 541-508-3944
    www.smallenginemachineworks.com & www.nwsleeve.com
    Turning Custom Cylinder Sleeves Since 1971
    http://forums.everything2stroke.com/...d-the-Shop.com
    Sep 2016
    Las Vegas
    9
    Well Its up and running. The shop fixed what ended up being their mistake. Someone at Wiseco got dyslexia and sent the wrong rings with the piston. The shop fixed everything and assembled it on the trike, compression is 160 now. Starts up now with one kick. Quite a bit of smoke now, but I think I went a little heavy with my 32/1 mix. I have done 2, 5 minute idles with a cool down in between, tomorrow I plan on a short ride keeping the rpms down. I want to thank you all for the help and info. I got 2 trikes up and going now
    2,355
    Glad to help.Also glad you didnt give up on it .These aircooled 250Rs are fun to ride.
    250r rules
