I have a post lower about a 85 350x I purchased for my son, all original, and so on. I am sending the carb to a member on here for adjustments and a tune, it's a def fuel issue. As i stated the first owner made the decision to place a chemical, either por-15 or Kreem or something inside the tank although there was no rust for preventive measures, bottom line is, it wasn't done properly. So.... I have a few options, my first was to tank the tank to a guy I know who restores cushmans, builds street rods and let him do his work. Unfortunately, the stuff in most spots is ON there. Secondly, a expensive complete send out for restoration, which I'm not opposed to doing, but not right away. Another option is to try to re coat the tank with the best possible system out there, and any input on this would be great, or input on removing the garbage job they did since the tank has no dents and all the decals in tact, which I can replace. Last option if I have to search, or send out for a complete resto job, is I have access to a new stock capacity Clarke plastic tank so i can ride the thing when i want until I figure this out. Any help would be great.
thanks
Bryan
