Results 1 to 15 of 23
Thread: What piston size would i need for a 65.72 bore?
    Oct 2012
    I picked up a 1984 200x and the bike had a loud piston knock noise and it smoked a lot. When i opened up the top end I found that the piston was 64.5mm and the bore of the cylinder was 65.72 or so. The piston is a brand new wiseco. Would a new piston that is 65.5mm work in that 65.72 bore?
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    I like to send jugs away to professionals who bore the cylinder to match the exact piston that they supply.
    Pistons can measure differently in different locations due to the anticipated exhaust side being hotter blah blah blah
    How this particular situation exists in real life is shocking to me.
    What else did the previous owner fix?
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Oct 2013
    Wherever I May Roam
    3,757
    That's peculiar since a stock piston is 65mm. This is why we can't have nice things.
    Oct 2012
    I hope nothing else is wrong with the engine. Im looking to get rid of this bike once im done putting it back together. So im thinking of picking up a 65.5mm piston and throwing it in.
    Oct 2013
    Wherever I May Roam
    3,757
    Quote Originally Posted by niftylittleguy View Post
    If you stand far enough back, and get a video of it, maybe dudeperfect will make you youtube famous.
    Oct 2012
    Well i'll have .2mm of play so i think i might make the shot. LoL
    Mexico
    9,019
    What did you use to measure the bore?
    It sucks to get old
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    I strongly advise against that option.
    Remember at the very minimum you need to get the bore honed to set the new rings.
    Let the pro's bore it with the correct forged or cast piston clearance.
    Do everything else correctly and survive with a good running, reliable engine.
    Oct 2012
    Quote Originally Posted by arlaunch View Post
    The cylinder has been honed previously. I dont think it needs to be honed again.
    Oct 2012
    Micrometer i got off amazon.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    This looks like a job for loganm, AKA "the piston whisperer".
    Aug 2015
    Portland Oregon
    174
    Howdy mate; your numbers are going all over the place
    64.5mm = 2.53937”
    65.5mm = 2.5787”
    65.72mm = 2.5874”
    A Wiesco piston for a 65mm bore would be .002”. Too many decimal points to work with, you’ll turn your brain in knots trying to work the numbers.
    A 65.72mm piston fits a 65.75mm bore, the difference .03mm is the new skirt clearance, .00118” don’t believe it. This is why the skirt clearance is printed on the Box; mostly, Wiesco pistons increase in 1/2mm or .020” steps.
    John Tice
    503-593-2908 Alternate 541-508-3944
    www.smallenginemachineworks.com & www.nwsleeve.com
    Turning Custom Cylinder Sleeves Since 1971
    http://forums.everything2stroke.com/...d-the-Shop.com
    Mexico
    9,019
    Quote Originally Posted by tripledog View Post
    LOL!!! Hell yea!!! He'd get a 66mm piston in that hole faster than you can scream "Put down that !"
    It sucks to get old
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Why must you leak down upon people that ask questions but don't listen to answers?
    Oct 2012
    The bore i have is 65.72mm. The closest piston to the bore i can get is 65.5mm. So there would be a .22mm difference.
