Results 1 to 15 of 16
Thread: Got any 350X headlight alternatives?
    Qdude79 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    CenCal
    369
    My headlight bezel is shot, don't want to shell out hundreds for a nice one to have to paint it black (my color scheme for my rebuild). Any suggestions?
    "Still occupied with 1985"
    200X- restored to near original and SOLD
    350X- back in black
    250R- she purdy...
    arlaunch's Avatar
    arlaunch is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    Oregon City
    346
    Number Plate?
    I think they look better anyway.
    1984 Honda Big Red ATC 200ES (Emma)
    1985 Honda 200X ATC (Pretty Boy)
    1985 Honda 250R ATC (Dr. Fast)
    1985 Honda 250R ATC ( 77 )
    1985 Honda 250R ATC (Baller)
    1986 Honda 350X ATC (Go Go Girl)
    Feed Back: http://www.3wheelerworld.com/showthr...k-for-arlaunch
    Jun 2003
    CenCal
    369
    I should have included that I do want a light. Never know when the ride goes longer than expected.
    350X- back in black
    250R- she purdy...
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    I new a fella once upon a time who had a 1986 250R with a 350X headlight. It was not just for looks either as it worked.
    I have an 85R and tried the same trick. There was no way for me to hook it up due to the plugs being totally different. I thought it looked good for awhile. Then went back to the number plate thing.
    I have never seen an R headlight on an X
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    I have a vested interest in your 350X project as i will have one soon too.
    Mine made metal big time in the oil filter.
    I have my R project just about wrapped up.
    I just need to install a bunch of parts that are waiting on my bench.
    Then i pull the motor and investigate.
    I am going to give Mega-Cylce a bunch of money this winter.
    Jun 2003
    CenCal
    369
    Looking forward to getting it in the dirt! My 250R is "finished" (are they ever "finished?") and I want a thumper.
    350X- back in black
    250R- she purdy...
    Mar 2003
    Australia
    1,919
    Why not go an LED light bar setup?
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Jun 2003
    CenCal
    369
    I like the idea, what extra would it require electrically?
    350X- back in black
    250R- she purdy...
    Apr 2002
    s.w. michigan
    6,498
    Option's
    I replaced my beat up stock air cooled 250r head light with LED (done tail light as well with brake light) and couldn't be happier.
    Not sure what all is needed on 350x as far as eletrically.
    My application was for my 300ex trike conversion that has battery, eletric start, rectifier and basically ready to go . I will get picture of the light mounted inside stock metal gaurd.
    Now as far as a option. You want black 350x headlight bezle. I have one left. It is a early proto type that I have not detailed trimming yet. 1 small drill thru hole on top I will repair. Mounting strap area will require some mods to your straps that go thru bezle and lock in with pins and I will included a set .
    60 dollars shipped. PM me a text number if interested .
    p.s. ~ no other bezles available, no I won't be making more + if Qdude don't want it ain't for sale,,,, just a fyi.
    Thanks, john
    Attached Thumbnails Attached Thumbnails 20161003_065302.jpg   20161003_065226.jpg   20161003_065210.jpg   20161003_065158.jpg
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    Here's the led setup on my 500x. Electrical, you will need a regulator/rectifier, cheaply found on amazon, and it is necessary to run a capacitor. Something like 3000 uf. If you'd like I can make up a wiring diagram as this question seems to get asked a lot. But only if you promise to post pictures when you're done
    Atc 500x for the win! (Hopefully.... one day)
    Jun 2003
    CenCal
    369
    I will absolutely take you up on your offer, John! PM sent.
    350X- back in black
    250R- she purdy...
    Apr 2002
    s.w. michigan
    6,498
    Cool. Got you pm. I will get to work on it tonight + stay in touch.
    arlaunch's Avatar
    Jun 2014
    Oregon City
    346
    I liked were this was going with some LED info.
    There is a fella over in the new members sections wondering about LED lights. Scora7 i believe.
    How lucky to get a nice custom X headlight in the right color for the right price.
    Jun 2003
    CenCal
    369
    No kidding!^^ Made my day! Thanks, John!
    350X- back in black
    250R- she purdy...
    Apr 2002
    s.w. michigan
    6,498
    Led
    Well Arlaunch, here is a pic of my led set up inside stock 83/84 250r headlight guard.
    There are so many different size of led assemblys available, ,,, just takes some searching (okay, alot of searching) to find something you can work with.
    My set up took a little outward bending of mounting tabs.
    Attached Thumbnails Attached Thumbnails 20161003_191849.jpg   20161003_191912.jpg
