Results 1 to 12 of 12
Thread: 250es won't idle and misses out when running
    Oct 2016
    TX United States
    3
    disassembled my carb cleaned it in varsol put everything back in, I am now able to run without a choke but I still can not let the motor idle or it dies and when driving it misses out. Carb is super clean, air filter looks good, Spark plug is decent condition. The adjustment screw really only seems to affect anything when I have it fully choked. Have a bit of slack in my throttle cable would that affect my idle enough to let it die on me? ANyone have ideas of what else to mess with to fix my issues above?
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Quote Originally Posted by Logan2015 View Post
    Check timing sound like it's out. . And also do a compression test. Also ride it around and post a pic of the plug
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Jan 2016
    US
    7
    I had simular problem. Change carbs twice, cleaned many times. It would idle good but choke out at 1/4 throttle. Worked on it for months
    Finally figured out dirt Dobbers built about 5 nest in the air intake up by the handle bars. On my 200m the intake hose ties into the frame of the bike and runs to the handle bars with 2 small holes for air to enter. Might see if you having same problem.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Sep 2016
    Northern In
    18
    You might double check the sediment bowl on the fuel petcock. And make sure the tank vent is working
    Oct 2016
    Oklahoma
    4
    Hi everyone! I am new to this forum and I am still trying to figure all of this out. ( This is definitely the most confusing forum I've ever been on.) I don't know how to find the thread for my issue. I recently acquired a 1985 Honda big red and it is not getting spark, I have replaced the following : spark plug, cdi, ignition coil, kill switch, and I believe that's it. Does anyone have any advice for me? Please help!
    Feb 2016
    Stellenbosch, South Africa
    186
    Make sure it is in neutral and that your ignition switch is properly working, we need more info, but start at the basics, is your battery good?, does your green neutral light come on? .... if all of that works your next step would be to look at your stator ...
    1983 Honda ATC250R
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Oct 2016
    Oklahoma
    4
    Ok so last night I went over it really well. My battery is good, yes my neutral light comes on along with the headlight and tail lights. I discovered that it was my pickup coil. Now the issue is getting a new one. I have found two on the internet but the one that is on my 3 wheeler seems to look different, like they've improved them or something. The ones that I have found have what looks like a connection on top and mine doesn't have that. My wires are soldered on and the one you can buy isn't like that.
    Feb 2016
    186
    1983 Honda ATC250R
    2001 Honda TRX90
    2008 Honda TRX250TM
    Oct 2016
    Oklahoma
    4
    I can imagine that is a reliable website. Have you ever ordered from there before?
    Feb 2016
    186
    I have never ordered from there no, but I would imagine a scammer would most def sell something different if it was not legit.
    1983 Honda ATC250R
    2001 Honda TRX90
    2008 Honda TRX250TM
    Oct 2016
    Oklahoma
    4
    That's kind of what I was thinking too. Thanks for all the help! Now can you tell me where to post something where a lot of people will see it? I'm looking for an exhaust and was wanting to know if someone had one for sell.
    TwiZ's Avatar
    TwiZ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2015
    Elk county Pa.
    187
    I see the coin thats in the pic on ebay all the time,junkboy i think it is. Seem like his stuff is waaaay overpriced,wanting like $15 for a couple mounting bolts.
    http://www.ebay.com/itm/85-HONDA-ATC...FSTHtT&vxp=mtr
    Not sayin he is shady,just used stuff thats super overpriced,and the one in the pic lookes used as well
    1984 Honda 200X
    1984 Honda 200S Bonecrusher
    1975 Jeep CJ5
