Results 1 to 12 of 12
Thread: 1985 honda 250r
    Nov 2013
    brawley, CA, imperial county
    125
    1985 honda 250r
    Has anyone bought those colored silicone radiator hoses from ebay, if so how were they in terms of durability and dependability? I was also wondering what coolant should I run, will 50/50 mix work or does it have to be a special coolant?
    Jul 2013
    USA
    737
    I've read here that the silicone hoses do not flex like the stock rubber hoses. That leads to a higher probability of blown head gaskets. Just passing that on, i personally have never used them.
    Nov 2013
    125
    Alright so that would be a negative on silicone hoses, what kind of coolant is recommended because i have no idea if i should use 50/50 or what.
    efhondakid's Avatar
    efhondakid is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2015
    Canton Ohio
    203
    Quote Originally Posted by fieldy View Post
    This makes absolutely zero sense.
    2 in the back, 1 in the front.
    Nov 2010
    Oshawa, On, Canada
    2,123
    Ive been running them for years with no issues. You will be fine
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jul 2012
    Joplin, MO
    597
    The silicone hoses work fine. I found that the cheap ones you have cut to fit some, they work great. No problems from mine in a year.
    Any 50/50 mix works. Nothing special. With the 50/50 you don't have mix. Just pour it in. I run Zerex Asian anti-freeze 50/50. But the green will work.
    Sent from my MotoG3 using Tapatalk
    devore,ca
    1,055
    I'm running them on my R. I had to cut quite a bit off of one of the hoses to get it to fit but they work just fine.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jun 2015
    stonecreek ohio usa
    654
    Yes the silicone hoses are fine, they had to be cut to fit. And 50 /50 mix works in my r. I've had no problems
    Tionesta, PA
    5,747
    Another plus for the silicon colored hoses. Some trimming required, but they look and hold up great.
    Nov 2013
    125
    Thanks guys, gonna bite the bullet and order some blue ones. If a 50/50 mix works what brand can I run in it, don't want to put car coolant in it.
    Slidell, LA
    4,738
    Sorry about that....thinking this iPhone is going haywire....anywho, you can just get the prestone 50/50 at autozone. Easy peasy
    Nov 2013
    125
    Alright thanks gonna go get that tomorrow and hopefully start her up for the first time this season, I mostly do my riding around glamis or sometimes the fields on the outskirts of glamis, i havent really found anyone with a trike out here.
