Results 1 to 3 of 3
Thread: Pipe to Header connection loose and leaking
    brandonlowe2's Avatar
    brandonlowe2 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2016
    Georgia
    412
    The connection point where the pipe connects is loose and leaking..... really makes a mess and sounds bad. I have known about it for a little while now, but, this week I am going to be able to get it out, clean it up and attempt to fix it.
    Anybody that has had this happen before and can give me a little "pre-advice" on how to fix it would be appreciated.
Name:	2016-10-01 16.17.55.jpg
ID:	235870Click image for larger version.
Name:	2016-10-01 16.18.03.jpg
    1983 Selvy 300R - Check out the Build Thread
    1985/86 Tri-Z - Build Thread Coming Soon
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    Youtube Channel "Lowe Off Road"
    - Brandon
    Williamstown PA
    5,825
    most of the 2 strokes do not run a o ring seal its just exhaust port to header. your springs help hold this one. high temp silicone your exhaust port and do the same with the pipes inside. install use new springs and let sit. should fix your issues. running good oil helps and so does the correct jetting and mixture.
    May 2016
    Georgia
    412
    OK, that sounds easy enough... I will get it done and report back with the results! Thanks!
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
