Thread: '81 185s w/front shocks??
    I just picked up a very used '81 185s, according to the frame sticker anyway, but it has front shock forks. All my research I cannot find where 185s came with front suspension. The front forks also do not bend in at the top, they are perfectly straight bottom to top. Would this front end be off of another??
    Nov 2002
    Kirkville, NY
    3,831
    Sounds like a 200x front end. Does it make the bike side up high in the front? Post some pics. if you can.
    -Andrew
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    May 2002
    Dublin, Georgia
    635
    check here
    Here is a pic of the 185S with front suspension. This is the stock setup
    http://www.files.3wheelerworld.com/Sads/sHonda1983atc200atc185sD.jpg
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Thanks, and the pic looks like it was even on this website.....my forks must have been changed out even so, they do not bend inward at the top like those do, it looks kind of funny, esp since it has no headlight. Haven't even got to ride the think yet, needs a new gas tank which should be here by Wend or Thur from Beatrice, the old one has been JB Welded so many times badly that it just rains gas along the seams. Thanks guys!!
    May 2002
    Dublin, Georgia
    635
    check these
    Do your forks look like these? http://www.files.3wheelerworld.com/Sads/sHonda1985atc200x.jpg
    If so, they could be 200x forks. If the front is sitting high you can adjust this style by sliding the tubes up in the triple tree some.
