Results 1 to 3 of 3
Thread: 1984 honda 200es spark problem
    Oct 2016
    holley ny
    Post 1984 honda 200es spark problem
    I have a 1984 Honda 200 ES that has a spark problem. For a while I was able to start it and ride it for a few minutes and then it would shut down, usually after a short hard ride, and it wouldn't restart.
    I would seem to loose spark. Every time I hit the electric start I would get 1 spark and no more. I've used new plugs,replaced the coil,cleaned all the wiring connections and grounds,still no luck.
    I just got a new cdi box , but I think it is for a 200s and when I plug it in I get a reverse light on the dash and no electric start. If I unplug it , the light goes off and the electric start cranks , but obviously no spark.
    I suspect the original cdi is bad and the new one is the wrong one, or possibly the pickup coil is bad.
    Any Ideas
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Sounds like a bad stator. You can test the wires coming from the stator with an ohm meter and the correct ohm reading is listed in the manual.
    6,813
    99% of the time it's the cdi on the 84 200es
    . It's a one year part and it's still available new from Honda .
    Got to partzilla.com for the best price .
    The 200s stator will not work
