Results 1 to 15 of 15
Thread: I screwed up my 1983 185s
    Oct 2016
    Sturtevant, WI
    7
    Hello and thanks for a great forum of info. I decided to use my 185s to tow my snowmobile out of my shed while the sled had its parking brake applied. Yea it didn't move. Regardless to say I have her hell trying to budge the sled before I realized what I did. I ended up dragging the sled out by hand and parking the trike. The next time I took the trike out it won't shift. Can't find neutral. And only seems to shift up. Or it's stuck in 1 gear. Not sure. Only time it's in neutral is when I'm pushing and holding the shift lever down. Then when I let up it ends up in whatever gear it's stuck in and won't let me shift down to neutral. It starts and moves under its own power. Just doesn't allow me to go through the gears.
    So what do I look for? I'm very mechanically inclined. However I've never messed with one of these.
    Thanks for any help
    Harold
    6,796
    Pull the clutch cover off , sounds like something is going on with the shifter star .
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    What shortline said. I would look at your tyranny gears too.
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Sep 2016
    Northern In
    18
    Take a good look at the manual clutch while you are in there also.
    Oct 2016
    Sturtevant, WI
    7
    https://youtu.be/cSZA65VVs4I
    Here is what I got. I'm guessing it's internal. Any suggestions?
    Oct 2016
    Sturtevant, WI
    7
    Anybody got any ideas. I'm getting ready to just unload it for parts.
    6,796
    Use a 10mm socket on the shift star and see if you can make it shift . You need to rotat the output sprocket shaft while trying to make if shift .
    Oct 2016
    Sturtevant, WI
    7
    thanks. yes i can indeed shift it through the gears using this method i have gone up and down while rocking the act back and forth and it seems to have freed up doesn't seem to shift with the shifter yet at least not accurately. i may be able to shift but it doesnt always respond how i want it to while going up and down
    6,796
    Then it's time to replace the shifter and star set up .
    Oct 2016
    Sturtevant, WI
    7
    I appreciate your help. Thank you. What would be the path typically taken? Buy a junk one and swap parts?
    6,796
    See if the parts are available new first and if not eBay is probably best .
    Partzilla is a good source for the new parts .
    Oct 2016
    Sturtevant, WI
    7
    according to that site just about everything id try to replace is obsolete. I'll work a bunch and see if i can free it up hopefully that will be enough. then start looking for junk ones i guess. Or i might just junk it too.
    thanks again for your help
    Oct 2016
    Sturtevant, WI
    7
    Good news. Everything works. After moving that star wheel a few times with the ratchet it seemed to loosen up. Started working the shifter by hand and it wasn't perfect but it shifted. So put it all back together put some oil in and test drive and all is well. Just need to adjust the clutch now
    May 2016
    OH Canada
    1,102
    That is good news. Keep us updated on the next drive.
    Weird of what happened. Can't shift... Maybe something. debris got into the shifter mechanism(?)
    May 2017
    Sask, Canada
    Im new to this forum, joined to find some answers myself. Have a 185s was driving it around in the snow playing around then fired it up after awhile of sitting and seems to be stuck in 4th wont go up or down. The shift lever just kinda wiggles. Anybody have any answer or suggestions for me that would be greatly appreciated. Thanks
