Results 1 to 10 of 10
Thread: 250sx rear shock replacement or rebuild/revalve?
    Apr 2016
    Columbus, IN
    60
    i have an 86 250sx with 86 250r forks on it. after rebuilding the forks the front end does awesome and soaks up all the bumps on the trails. The rear is a different story, being the original shock im guessing that it is more then likely blown. On the trails it seems like the rear bottoms out pretty easily.
    I am trying to stay under $100 to do this. I have read on there that the 300ex rear shock is a direct replacement and gives a better ride and can be found for a reasonable price. I wanted to get your guys' opinion on if i should just do that or if getting my stock one rebuilt and revalved would be worth it or even in the price range im looking at. Where is a good place to have it rebuilt? I mostly do some faster paced trail riding.
    let me know what you think
    "If you're gonna be dumb, you gotta be tough"
    ** 1986 Honda ATC 250SX - '86 250R forks - LED headlight - 250r gold wheels **
    I don't believe they can be rebuilt (and definitely not for under 100$). Get yourself a 300EX shock.
    Nothing will match that 250R front suspension in the least, but you can certainly make it better...
    Aug 2014
    South Louisiana
    1,915
    With some massaging I fitted a 350x Shock but it was much too stiff and the geometry was a bit off. It may have been better with a different spring. Just gotta experiment a bit.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Jan 2013
    minnesota
    5,911
    Nothing will match that 250R front suspension in the least,...
    Unless you use a set of forks from the 86 "TECATE....The Most Powerful 3 Wheeler In The Universe!".
    OMG...I think I just burst a hemorrhoid!
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    ? Will the 300ex shock work in the bigreds ? I've been wanting to upgrade the big red shock
    Apr 2016
    Columbus, IN
    60
    Quote Originally Posted by big specht View Post
    from what i have seen here it should bolt straight in on the 250es (bigred) and 250sx.
    Jul 2015
    Maryland
    16
    The 300EX shock will fit on the SX, but the bolt holes on the frame/swing arm of the trike are a bit smaller. I ordered 2 of these to compensate:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    The 300EX shock is stiffer than the SX shock, which was good for me because I'm a bigger guy. I run a 200X front end on mine, and it compliments it nicely.
    Jan 2016
    Little Rock, Ar
    83
    Quote Originally Posted by mdmike View Post
    What year model of 300EX shock did you get? I have a '87 250SX that needs a better rear shock and I'm looking for the alternative to stock.
    '87 ATC 250SX
    '86 ATC 350X
    A bunch of stuff-n-stuff
    axeman24 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2016
    long island NY
    247
    ive been told a blaster front shock will work and give it a softer ride but its a half inch shorter and ive got a 350x front end on my sx so id like a LITTLE more height
    Jan 2016
    Little Rock, Ar
    83
    No dowels are needed when replacing the '87 SX rear shock with a '93-'00 TRX 300 rear shock. Bolts right up.
    Attached Thumbnails Attached Thumbnails 20170214_140521.jpg   20170214_140554.jpg   20170214_140654.jpg   20170214_141415.jpg   20170214_142109.jpg
    '87 ATC 250SX
    '86 ATC 350X
