I installed a uni air filter since the first day i have had my 1982 185s,
and it has always had a hesitation and trouble running with no choke since the beginning. When on no choke when i give it gas fairly quickly it goes brrrrrrrrrrrrr and if you hold it it will stall , but when
i put it on mid choke it runs great, but when i run it on mid choke it
fouls the spark plugs(what is expected when running on choke for extended
periods of time). What i am asking is that since the stock air filter
is very restrictive and since the uni air filter is very open and air
flowy i think i am running on a lean condition. ANd i did a plug chop to
test my jetting and it was mostly white meaning lean and hot(right?), so my main question
is where can i get bigger jets a couple sizer bigger than the stock jets
on the 1982 185s, i have replaced everything on this bike a new head a brand new carb and carb kit, a new cylinder, bored with new rings, new piston, the stator pretty much everything.
Does anyone know why in the helln its doing this.
if anyone doesn't understand what it is doing in terms of how it sounds i will then make a video of it and post it so you can see the wierd hesitation and judge it.
howdy told me to post on the forums and i hope this works.
thx
