Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 95
Thread: scratch building 85 250r.
    Carthage NY 250r rules
    2,355
    Thanks Barnett.I was trying to remember what company made these adjusters.I would like to go the cr ignition route but its pricy.I found a pvl for $250.But I can get a lightend flywheel for $15.and these adjusters arent to pricy.
    250r rules
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by atc300r View Post
    Thanks Barnett.I was trying to remember what company made these adjusters.I would like to go the cr ignition route but its pricy.I found a pvl for $250.But I can get a lighted flywheel for $15.and these adjustets arent to pricy.
    No prob, you're welcome and lots of people here know more about these than I do but as far as the engine goes, they are all pretty much the same
    Do you mean a "lightened" flywheel?
    I think ride red 250r is familiar with one of the ignition conversions like maybe a 2001 cr250 cdi box but he or someone else can tell you more about that.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    2,355
    Spelling error. I agree lots of 250r knowledge here. Plus I go on the trx 250r sites same motor.plus I have owned my 85 250r since 85.This is going to be my race only trike.
    250r rules
    Jan 2013
    minnesota
    5,911
    Spelling error. This is going to be my race only trike.
    Ok, I have done a lot of flywheel weight testing on both motocross bikes and 3 wheelers and can tell you that unless you are a pro level racer, a flywheel that is much lighter than stock will not help you and will likely make you go slower . Even if you are a pro level racer, it still may not help . Flywheels are on there for a reason . If you are less than a pro level racer I would also suggest that you do not get a pro level port job either . In my experience, the best thing is to get an "intermediate" level port job and stick with that until you start winning the intermediate class . Once you are good enough to do that you can modify the cylinder some more if you want but it is kinda hard to "unport" a cylinder . A pro level rider on an average bike will spank the bejesus out of an average rider on a pro level bike every single time.
    One constant that will benefit most, if not all skill level riders is more compression.
    Slidell, LA
    4,738
    To be honest, a CR ignition is great but you need to "learn" how to ride the bike all over again. I used it in 2013 racing in Sikeston. The lighter flywheel stalls in the corners. The different curves on the ignition are a plus but to me the stock ignition with the OEM flywheel better suited my riding ability. Plus the sticker price for the entire kit is a pretty big deterrent. if you do get one, make sure its the 2001 and my advice is to ditch the 2001 flywheel and talk to BDT (carlos) about his "modded" stock flywheel for the 2001 CR ignition. Its beefier and doesn't stall as bad.
    2,355
    Thanks for the info yaegerb. I agree on the high price of the cr ignition. The pvl setup I saw for sale would have the same result as the cr to small of flywheel. Im going with stock and I will try the lightend stock flywheel if it doesn't work I can change it. I also race drags probably more suited for that.
    250r rules
    2,355
    I started painting some of the hubs and brackets for the 250r racer. Im just going to paint things no powder coating. Id like to paint the fork sliders and triples gloss black also the swingarm. So far the rear axle hubs, disc brake hub and lower gas tank mount brackets are painted gloss black. Click image for larger version.
ID:	238996 Click image for larger version.
ID:	238997 Click image for larger version.
    250r rules
    2,355
    Bought new reeds for my Boyesen Rad valve. Click image for larger version.
ID:	239410 Click image for larger version.
ID:	239411 Click image for larger version.
    250r rules
    2,355
    I bought 2 new motor mount bolts .Got them today. Front and bottom.Click image for larger version.
    250r rules
    2,355
    Got some more painting done on the axle lock nut ,sprocket nuts ,disc hub and bolts. Click image for larger version.
ID:	240291 Click image for larger version.
ID:	240292 Click image for larger version.
    250r rules
    Coming along very nicely!!
    2,355
    Im waiting for the weather to warm up so I can take my frame outside and do some welding on it. Also I want to pull the motor off my 85 250r and take it apart so I can send the cases to BDT for welding. I need to cut down an oem rear bearing carrier tube for my dual row carrier. I want to press out my steering stem so I can change the bearing and put the stem in a nicer lower triple clamp.Im hoping to have this trike done by April first so I can ride it and get it broke in before racing.
    250r rules
    2,355
    I bought a new fork air cap from Honda dealer . I got my rear brake pedal,spring and actuator painted.Click image for larger version.
ID:	240803 Click image for larger version.
    250r rules
    2,355
    Im putting this on hold for now.I found some thin spots in the frame.Someone used a grinder to strip paint and got to carried away.Couple spots thin as paper. Click image for larger version.
    250r rules
  15. #30
    Buffalo, NY
    1,994
    Dang, that sucks. Are you putting the whole project on hold?
