Thread: Big Red 250ES New Tires - too wide?
    Nov 2016
    Lincoln, NE
    3
    Replacing Kenda Dirt Dog 25x12-9 tires and bought Carlisle Trail Wolf 25x12-9 tires. Figured that tire sizes were the same but when the new tires arrived they look about 3 inches wider and 2 or so inches shorter than the Kenda tires (see photos). I know the tires will be taller once mounted and inflated and would expect them to be somewhat narrower, but I am concerned that the new tires will not clear the brake lines once mounted and inflated. Any idea how much I can expect these tires to "narrow up" once inflated? The first picture shows the old tire on the left (narrower) and the new tire on the right (wider). The second picture is showing the new tire on the left (shorter) and the old tire on the right (taller). None of the tires pictured are mounted.
ID:	236758Click image for larger version.
    Oct 2016
    fargo, nd
    21
    I dont think theyll narrow up too much unless you go to a slimmer rim...not sure though
    Sent from my SM-G930P using Tapatalk
    Nov 2016
    Lincoln, NE
    3
    Found this on the web that explains the dimensions stamped on the side of the tire. http://www.nalsa.org/tire-facts-chart%201.pdf Also contacted Carlstar Group, the manufacturer of the Carlisle tire and they said the OD on the tire will be 25.6 inches and the section width of the tire will be 12.3 inches wide once the tire is mounted and inflated. Wish me luck!
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Post some pics of them installed on the machine .
    Nov 2016
    Lincoln, NE
    3
    picture of the mounted and inflated tire on the left, unmounted tire on the right as well as pictures of the new tires mounted on the machine. I couldn't believe how much the width of the tires changed after mounting and inflating.
ID:	236790Click image for larger version.
ID:	236791Click image for larger version.
ID:	236792Click image for larger version.
