Results 1 to 3 of 3
Thread: 250r front sproket
    250r front sproket
    On an 86 250r is the front sproket supposed to have play on the shaft? I can move mine about a quarter of an inch in and out on the shaft even though the end bolt is tight. I was just wondering is it supposed to be that way or is something wrong with mine. The splines are still good and it doesnt slip that way, just in and out. Thanks
    1983 Honda 110 - Sold to bornonthreewheels
    1986 Suzuki 185alt- converted to Quadrunner LT
    1986 Honda 250R
    Las Vegas, NV.
    2,487
    Since you didn't appreciate the sarcasm on your handlebar question, I won't use any this time. No, there shouldn't be any play at all. It sounds like someone has installed an incorrect sprocket, or you're missing the spacer on the countershaft behind countershaft sprocket.
    Ashland City, TN
    2,576
    Hmmm....good question. My front sprocket on the Tri-Z has a little wobble too, I think it should though because if it's tight against something else it will wear it away. Dunno!
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
