Results 1 to 12 of 12
Thread: Finally got the Warrior headlights...
    Nov 2013
    Oxford CT, New Haven County
    984
    .... and got them mounted to the DXN. But I cant see if they work or not because this POS wont start again!!! lol It was running great, I shut it off, a few day later put the lights on and she wouldn't start again... I hooked up a battery charger and she fired up after a few minutes, ran on idle for about 2 minutes then stalled out and wouldn't re start.. so i pulled the carb...YET AGAIN!! UGGGHHH! and it looked like there was regular motor oil mixed in with the gas. Is it possible for oil to get into the carb?? anyhow I took it all apart, cleaned it and all the jets and holes and ports, put eh back to gether, drained out the gas tank, added clean new gas from a different can and couldn't get it to run. got pissed off and put it away. The last time it wouldnt start, i pulled off the air cleaner and it fired up. this time i did the same but nothing, but thats when found the oil-ish stuff in the carb. ok back to the drawing board.
    Anyway, here's how she looks now with the warrior head light set up.
    Mar 2013
    Central PA
    2,362
    That's awesome. Reminds me of the Baja trikes. Did it take much work to get them to fit?
    Nov 2013
    984
    Quote Originally Posted by Ghostv2 View Post
    nahh just had to figure out a way to mount them and to also mount the dash board. I ended up using thick zip ties to mount the dash board to the where the handle bars mount and then i put a bolt through the hole in the headlight cage, into the bottom mount of the dash board... the hole i used in the head light cage im guessing was for the wires to go through on the Warriors.
    Then I made two support bars that go from the front bottom of the Warrior headlight cage to the bolts that tighten around the front forks (where the original Tri-Z headlight cage bolted) Its really sturdy and isn't going anywhere.. lol
    Carthage NY 250r rules
    2,355
    That's a sharp looking DX.
    250r rules
    Manheim, PA
    5,817
    Pretty sure warrior ones were same as banshee ones. I like it.
    Sulphur Springs,Texas
    1,005
    Looks really good that way. They remind me of the headlights from the bike off "The Dirtbike Kid".
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Manheim, PA
    5,817
    love that movie! YZ80's rule
    May 2016
    OH Canada
    1,102
    What air filter do you have on it? Maybe it is over-oiled(?)
    I like the look.
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Quote Originally Posted by czac View Post
    ooohhhh lala! She foxy but only teasy
    Sent from my SM-G935V using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    May 2015
    1,081
    Nuhhuh warrior's lights were bigger in diameter.
    Jan 2008
    Willowbrook, IL
    856
    Either way, Warrior lights or not, looks Badass!
    Sent from my SM-G930V using Tapatalk
    85' Honda Big Red
    09' Yamaha YZ 250F
    2012 Polaris Sportsman 500 H.O.
    2015 Polaris RZR 570 LE/Trail Edition
    2017 Suzuki DR-Z400SM
    May 2015
    1,081
    It does. Like I said it's foxy :
