Results 1 to 13 of 13
Thread: 1984 atc250 starting problems
    Apr 2014
    Australia
    580
    Hey guys
    Ivan here from Australia, I have a 200es and just purchased an 1984 atc250r! When I brought it, it started straight away, then after riding for ten mins, it completely stopped! I couldn't get it started for 45 mins! It got to the point that my right leg was so sore! Are they hard to kick over? New to the atc250. What do you guys suggest? Clean the fuel tank, carby and buy a new plug?
    Thanks Ivan
    Sep 2016
    Ny
    39
    What i always do is make sure I'm getting spark,check this when the bike isn't starting. If your getting spark then you have a fuel issues.I just got my 81 running and it's a lot of fun.good luck
    Apr 2014
    Australia
    580
    Ritz, yes it does have spark when it isn't running. What do you suggest to do next? Clean out the while fuel tank and carby?
    Thanks Ivan all new to the atc250, my first purchase
    Sep 2016
    Ny
    39
    Is the plug wet when u check to see if it's sparking. If not wet it's not getting fuel. Also is it a nice strong spark. Is that 250in avatar, it's a nice looking bike
    Sep 2016
    Ny
    39
    I'm not sure if you've been to it but air foolers is another good forum for the 250r
    Apr 2014
    Australia
    580
    Ritz the plug is wet, but it doesn't look like the strongest spark.
    Sep 2016
    Ny
    39
    When the bike is cold check the spark, see if it's better then when the bike won't start. If it's better when it's cold I would thank your coil is getting bad. Warms up weak spark cools off good spark. Hope this helps
    Sep 2016
    Ny
    39
    I was reading someone else thread they were having same problem and they suggested that the stator could be going bad or maybe vapor lock. When bike dies open gas cap and see if it will start. As for stator I would get a manual and see how test it
    Apr 2014
    Australia
    580
    Thanks Ritz i will try tonight and see how i go
    Apr 2014
    Australia
    580
    Ritz, I put a new plug in it and sprayed a bit of starting fluid down the barrel before I put the plug in! Opened the gas cap and it started first kick! Then I put the gas cap back on and rode for about 15 mins then it died! They I couldn't start it again! Maybe I should have tried to open the gas cap and try to start it! I'll try that on the weekend! Is my gas cap blocked? What should I do? Thanks Ivan
    Slidell, LA
    4,738
    Quote Originally Posted by ivan-083 View Post
    See if you can blow through the vent hose into the cap with your mouth. There should be a little restriction, but you should be able to blow through both the vent hose and cap. If you can't, then your cap is clogged.
    Apr 2014
    Australia
    580
    Thanks for the information yaegerb! I'll try tomorrow and see!
    Apr 2014
    Australia
    580
    Yaegerb, the cap is fine I can blow through it! It looks like it's got a weak spark! So I put my ignition coil from the 200es and it still won't start? Any suggestions?
