Results 1 to 8 of 8
Thread: Big red 250 winch?
    Nov 2016
    Louisiana
    Big red 250 winch?
    Is it worth putting a winch on a big red? I would install on rathe front rack after I beef it up
    YBW is offline New to the board Arm chair racerNew to the board
    Jul 2016
    Buena Vista, VA
    41
    With how light the front is I can definitely see where it would come in handy. What are your plans for beefing up the front rack? It seems like the ones I have seen people with just left the rack stock, though I could be mistaken.
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    The one I just picked up had the stock front rack removed and replaced with a 1" angle iron frame built to hold a winch. I am 291lbs and stood on it to test it. Seems like it would work and cheap to build
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Nov 2016
    Fl
    13
    I think it will work fine. There's some people here who have a winch on their Big Red. A winch will just run battery down quickly so just charge up after using it.
    Jun 2006
    Omaha Nebraska
    321
    Quote Originally Posted by jervin36 View Post
    Anyone add a larger battery to their 250es? I don't use the trunk and will be using a winch a lot for plowing. I was thinking of swapping a larger battery and mounting it in the trunk (Just extend the wires). Maybe mount a battery tender/trickle charger to the set up so I could just pull the plug out of the trunk and plug it in while sitting to keep it topped off.
    Dec 2012
    812
    Whenever I see a winch mounted on the front of a 250ES I always wonder if it is more than these machines can handle. Winches mounted on quads are generally attached to the frame in some way, whereas mounting to the front forks (which is the only way possible on a trike) just doesn't seem strong enough considering the torque that's applied when the winch is being used. Don't get me wrong, the 250 Big Red's are very solid machines, but it just seems like installing a winch may be pushing the front end to the limit??
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    Quote Originally Posted by RUNMEDOWN View Post
    A guy I know put a farm tractor battery in his trunk. Everything works great as it should.
    Apr 2014
    Edmond, KS
    2,591
    Or you could also keep the stock battery and mount a second one in the trunk. Just run extra battery cables and connect positive to positive, negative to negative.
