Thread: ATC 110 into CT 70
    Oct 2014
    Edon, Ohio NW corner
    71
    ATC 110 into CT 70
    Anyone ever tried to put a late model 110 engine into a Honda CT70 frame?
    Dec 2007
    Quebec,Canada
    1,014
    First it's not the same bolt pattern,110 engine is longer,not sure if it clear front fender
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Aug 2012
    richmond nh
    647
    Dratv.com makes a adapter so it can be done fairly easy.
    Oct 2014
    71
    Quote Originally Posted by roostin atc View Post
    Thanks I will check it out.
    Oct 2014
    71
    Was on the site, seen a wiring harness for conversion, but no hardware.Was I in the wrong spot?
