Results 1 to 13 of 13
Thread: 350x cases
    Jan 2014
    Prescott az
    720
    350x cases
    So I just purchased a set of cases off of ebay for the 350x to build it back up after the chain incident. In the description online they said minor scratches and you couldn't see in the pics but has a small hole in the upper part of the case in the chain area, I think it will be ok just want to see what everyone thinks.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Worcester, MA
    1,117
    I'd add some JB weld to the outside of it, but first mix the JB with some aluminum shavings or even powder.
    Sulphur Springs,Texas
    1,005
    maybe it is just me but I would return it, I guess if you had seen the hole before would you still have gotten it?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    I'm fairly certain that just seals an empty orifice, correct? If so JB Weld as was stated. JB Weld is more than strong and durable enough to seal that indefinitely. You could even fill the entire orifice.
    Jan 2014
    Prescott az
    720
    Quote Originally Posted by Hondatcs View Post
    No I wouldn't have.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Jan 2014
    Prescott az
    720
    Yeah its empty I might try it unless I can find someone to weld it.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Don't even bother with the welding. You're at more of a risk (which is low) of destroying the case welding it. That's a JB Weld job all day long, exactly what it was made for.
    Jan 2014
    Prescott az
    720
    Alright ill do the jb was thinking about filling the hole like you said but its got paint in it and too small to sand it think it would stick?
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Tough to say not being there in person. Just get in there as best you can and clean it out good with brake cleaner, you should be fine.
    May 2009
    S.E. Michigan
    1,251
    As previously mentioned:
    1. That area is double-walled area. The hole leads to a separate sealed cavity. The crankcase is still sealed, so really you don't need to do anything.
    2. Straight-up JB weld is the way to go. I've fixed a few cases this way. I don't like to fill the cavity all the way up, because if a chain jump ever happens again (and you don't have a case saver installed, see #3 below) being solid will result in breaking through both walls. Use a piece of cardboard or plastic to back up the outer wall and apply JB weld on the outside. Once cured, you can use a dremel sanding drum to smooth it out all even and then paint it and it will look like new.
    3. Make sure to install a case save when you put it back together, it is mandatory. Check the 3WW parts store. Tapper has reproduction case savers there for sale.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    I agree with everything wonderboy says and he makes a point about why it may be better off not to fill it completely. I also agree, case saver is mandatory.
    Freedom Township, MI
    642
    Don't even ride it around the yard until you get a case saver. It's hard to resist not riding it but you have to-that case isn't too bad; don't make it worse.
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
    Jan 2014
    Prescott az
    720
    Yeah ill get the case saver taking no chances.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
