Results 1 to 10 of 10
Thread: 250sx centrifugal clutch
    Nov 2014
    Jackson, MS
    21
    I am looking for a new centrifugal clutch assembly or new parts for a rebuild. I've looked on Partzilla and BikeBandit and the parts are discontinued. Any information is greatly appreciated
    Feb 2013
    Senoia, Ga
    635
    ^ Thats the main clutch.
    It's just springs, shoes and deglazing or replacing the mating drum., Someone must have an easy fix for this. They'll chime in...
    Feb 2013
    Senoia, Ga
    635
    Oops, my bad. I read clutch and ran with it.
    Apr 2014
    Edmond, KS
    2,591
    Maybe you could use one for a trx 300.
    Nov 2014
    Jackson, MS
    21
    I was wondering if one for a 4wheeler would fit, but cant find any info as to what years or models will work. Good idea, Thank You
    6,786
    It tried the Trx300 idea a couple years ago , their different .
    I imagine you can use the 250EX as well...
    Aug 2016
    East of Worcester ma
    1,353
    This Honda 22535-HA0-405 WEIGHT SET, CLUTCH is used on these models and components:
    1985 ATC250ES A CLUTCH
    1985 ATC250SX A CLUTCH
    1985 TRX250 A CLUTCH
    1986 ATC250ES A CLUTCH
    1986 ATC250SX A CLUTCH
    1986 TRX250 A CLUTCH
    1987 ATC250ES A CLUTCH
    1987 ATC250SX A CLUTCH
    1987 TRX250 A CLUTCH
    I just copied this from a parts site it may help? In your search-
    Oct 2019
    OK
    I know this old post but has anyone found a replacement for the centrifugal clutch? Or once they are worn out just have to put find used ones?
    I didn't know if any other centrifugal clutches would work? Find one where it's the same sprocket and size just different housing and guts? I have searched high and low for a new one. If anyone can chime in and let me know.
