Results 1 to 12 of 12
Thread: Anybody got 2nd gen tecate extended swingarm pics?
    Mar 2009
    halifax
    237
    Anybody got pics? Homemade or pro.....
    Thanks
    Jul 2012
    Seattle, Washington
    1,543
    Heres a few stock 86 swing arms, and a +6 1st gen t3. You can use the 1st gen t3 swingers on the 86/87 tecates with the 1st gen rocker arm.
    Jan 2013
    minnesota
    5,911
    Why do you want a longer arm?
    Google is your friend.
    This first gen home made one below will flex like a rubber band
    rare champion for first gen
    custom first gen arm from hreatv.com . they can make a second gen arm
    home made
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by 3 Wheel Drive View Post
    Yes but the 84 rocker is even different than the 85 one, and since both are different than the 86/87, the ratio will be different if you use the first gen arm and rocker on an 86/87 . In 85 we used a rocker that had a more progressive ratio that I had selected to reduce the harsh bottoming the 84 had and I changed everything for the 86/87 model and that model is nearly impossible to bottom and works noticeably better than both the 84 and 85 . In fact, top PRO rider John Neary raced his 86 TECATE....The Most Powerful 3 Wheeler In The Universe, with box stock suspension, and although he did say that it was a little soft for his 210 weight, it was still rideable in the PRO class . . I only weighed 155 when I did all the development testing on it.
    .................................................. ... DON'T TRY THIS WITH A BOX STOCK ATC250R .................................................. ....
    Apr 2002
    s.w. michigan
    6,498
    Nothing up close Lawrence,,,
    86/87 swing arm extended 2 additional inch's on my 84/85 Tecate (which gives 4 inch longer then stock 84/85 swing arm). It has gone thru several color changes over time.
    john
    East Central Illinois
    677
    There is a thread about rare tecate parts if you search, should have photos of the west coast, calfab and laegers for 86
    nstyle73
    "When in doubt, wind it out"
    Feedback: http://www.3wheelerworld.com/showthr...k-for-nstyle73
    Arizona
    843
    I've got a Westcoast on my 84 and a CALFAB on my 86. Here are some pictures.
    Attachment 237761Attachment 237762Attachment 237763Click image for larger version.
    Mar 2009
    halifax
    237
    I've been collecting parts over the last few years for a 500cc tecate and have most of the parts. I'm just curious as to some of the ways people have extended their swing arms.
    Williamstown PA
    5,825
    do you need a new one built because www.hreatv.com makes 1st and 2nd gens with options to go to round house carrier off a 400ex.
    http://www.hreatv.com/custombuiltparts.html
    Buffalo, NY
    1,995
    Here's my old 500, I had a HRE made at the suggestion of old-school and a couple others. I wanted the Honda carrier because the torque of the 500 would pull the right side adjuster back, no matter how tight I had everything. I raced it, on a trail bike you might not have the same problem. This was a +3 and I loved it, the only thing I'd have changed was to ask for brake line clamps on itClick image for larger version.
ID:	237776Click image for larger version.
    99gsxr750 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Eastern Pa
    219
    Quote Originally Posted by jeswinehart View Post
    john
    Hey John,
    What parts did you use to make that dog bone and did you relocate the mounting point on the swing arm?
    Mike
    Oct 2013
    New Hampshire
    77
    Second that on hre they are awsome worth every penny and they can build any way you want for most part. What did you get for exhaust system.
