Thread: 2011 Honda Shadow Trike Conversion
    Feb 2003
    New York
    619
    Hi all. I think I covered all bases exhausting any possibilities of a reverse gear for the 2011 Honda Shadow 750.
    Is there a way to go with an electric reverse gear ? No one seems to manufacture anything for this bike which has already been converted to a trike. Moto Trike is the manufacturer of the trike kit installed. I checked with Moto Trike and they do not offer a reverse gear for the Honda Shadow 750. This is shaft drive. I might consider some type of fabrication as long as it is professionally done. If you hear of anything please give me a shout. Thanks !!
    ♠ 58 ♠
    Ride 3
    Mar 2013
    Baldwin, Wi
    603
    The Goldwing has electric reverse and uses a starter motor. You might be able to fabricate for the shaft with a starter motor and a one way bearing.
    85 Tri-z Basket Case
    Feb 2003
    New York
    619
    Yeah I know the GW has E reverse and I am looking to do the same with this smaller Honda. Will the oem drive shaft be able to turn in the opposite direction ?
    ♠ 58 ♠
    Ride 3
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by sweetip2000 View Post
    As long as it's in neutral. I think it would be cool to rig up a small electric motor to just the front wheel for reverse.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Mexico
    9,014
    I’ve seen lots of these reverse setups on three wheeled conversions that use diffs. At a glance I’ll assume they adapt to the output shaft that normally uses a sprocket, but maybe you could get an adaptor made for whatever drives your shaft. You might try sending out some inquires to the guys on Alibaba to see what’s available.
    https://www.alibaba.com/trade/search...sGalleryList=G
    It sucks to get old
    Feb 2003
    New York
    619
    I just don't know why so many trike kits are available but most of them do not offer reverse. Do they think an old man is gonna get off the bike and pull or push it back ? By old I mean a rider who is 80.
    ♠ 58 ♠
    Ride 3
