'84 250R advice
I know I had originally told you that you may want to keep the bike original based on how clean it looked, but now that you've said all that it changes things a bit.
If you need change out the exhaust, that's simple enough. Find a decent aftermarket setup and swap it out. If the bike isn't running smoothly then there is a good chance you'll have to dig into the carburetor. It could just be dirty, it could be worn out from age, or it could just need to be jetted. If you're going to replace the exhaust you will have to jet the carburetor anyways. I can help you cross that bridge when you get to it. It may behoove you to buy a nice brand new carburetor for the best running quality and performance. I had an 81 300R which is the exact same engine you have but with a Hondaline big bore 300cc jug. Big bores are great as well if you decide to go that route, but that's not my point. My point in bringing that up is that bike was the absolute smoothest running two stroke I have ever owned. Bottom to top the bike was always on the power and there was never any coughing, burbling, or ring-dinging, which means your bike can be that way as well once you get everything sorted out.
When you say there is play in the rear axle bearing housing, I'm assuming you mean between the axle and housing as opposed to the housing being loose in the swing arm, yes? If so, simply replace your rear axle bearings and seals. It's not very difficult. While you're there you can diagnose and correct the caliper problem.
Is your front master cylinder cracked and warped or are you talking about the plastic reservoir for the rear master? If the front master is messed up you can get a master cylinder from any dirt bike or quad to replace that. The rear reservoir I would imagine could be replaced by a reservoir for something else if you can't find the correct R reservoir.
