so I finally got a new DG exhaust set up off ebay for a good price and went to take off the stock head pipe on my DXN 225, both bolts were stripped and the allen wrench just slipped around inside it so I used a "rounded" bold remover and got one out, the second one, the harder of the two to reach, wasnt as easy, the bold broke off leaving me just enough sticking out to grab with a vise grip but couldn't turn it cause it hit the fins on the head.
long story short, I broke the casting around the bolt.
luckily I had a seized motor in the garage with a good (well, not busted) head on it. I took it off and cleaned it, everything looked good so I put it on my motor, re did the timing, adjusted the valves and all but now the bike wont start.
it starts and runs only with starter fluid sprayed into the spark plug hole and will run on the fluid for a second or two but thats it.
I took the carb off and cleaned it and tried a newer main jet that was the same size but still got nothing,
I tried disconnecting the air intake figuring it may have been chocking out, nothing...
I even pulled the baffle out of the new tail pipe... still wont start.
Any thoughts?
I know sometimes you may have to re jet the carb with these aftermarket pipes... but it runs on the starting fluid. Its almost like its not getting gas into the cylinder but the Spark plug is wet when I take it out.
Could it be the air mix screw maybe?
I usually run it 1-1/2 turns out with the stock pipe and even when I had the YZ 250 muffler on it... maybe I should try 2 or 3 turns?![]()
