Results 16 to 30 of 31
Thread: Engine Seize - Time to Rebuild the Tri-Z
    brandonlowe2's Avatar
    brandonlowe2 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2016
    Georgia
    412
    Quote Originally Posted by christph View Post
    I see you are thinking about getting GPI radiators--I am too. Even though I have a hi flow impeller, a Sprock cool head, and use Engine Ice on my Z, I still have an occasional problem with heat fade. I bought an aftermarket radiator for my 1st generation Tecate and it cools much better than stock, but several of the aluminum tabs broke after one ride. I got them re-welded and re-enforced so they are fine now, but I'm worried about the same problem with the Z radiators. I think all the oversized radiators on ebay are made by the same company in China. Does anyone have experience with these radiators they can report back?
    Yea I have read some bad things about the chinese radiators, but, at the same time its the only game in town for a bigger capacity and aluminum radiator. Which Hi Flow impeller did you go with? and do you have a link for the Sprock cool head you refer to? I want to do everything I can to keep from overheating again. I was told about http://www.trailtech.net/ today... these look like really cool devices and I am planning on getting one.
    1983 Selvy 300R - Check out the Build Thread
    1985/86 Tri-Z - Build Thread Coming Soon
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    Youtube Channel "Lowe Off Road"
    - Brandon
    May 2016
    Georgia
    412
    I don't know how I missed it before but I just saw your pictures of your different fork set ups.... I never even thought about having more than one setup... they look awesome
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    Arizona
    843
    I get a lot of my Sprock parts from Greg at Off Road Innovations. Sprock is no longer making this stuff so you better act quickly--although Greg has talked about making these parts himself. I have all the parts below and my Z is a beast. The last part listed below--the V-Force reeds--is not from Greg. I snagged the last one from him a few years ago.
    http://www.ebay.com/itm/Sprock-Racin...xXESk-&vxp=mtr
    http://www.ebay.com/itm/1983-1987-Ya...IAAOSwiYFXI-j2
    http://www.ebay.com/itm/NEW-Yamaha-T...0AAOSwZJlXM124
    http://www.ebay.com/itm/Yamaha-Tri-Z...xYLKA4&vxp=mtr
    May 2016
    Georgia
    412
    This is going to cost some serious $$$ lol..... it will be fun though. What size carb are you running?
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    Mar 2013
    Baldwin, Wi
    603
    Quote Originally Posted by brandonlowe2 View Post
    From the picture, it looks like you have quite a few mods on yours... can you post more pics and list what mods you have?
    This is my build thread.
    http://www.3wheelerworld.com/showthr...werValve/page3
    85 Tri-z Basket Case
    Jan 2014
    Prescott az
    723
    Im doing my build now too mines all stripped down. Doing my forks tonight.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Jan 2013
    minnesota
    5,911
    barnett468.... i only assumed (and you know what assuming does!) that with the top end upgrade that I would want a little more rear end length to help keep the front on the ground going into 1st and 2nd. 2" in my mind just doesn't seem like a lot, but, if you say it is I need to look into that as an option. I love the way the bike handles right now and I don't want to change that drastically... I just want to accommodate for the added power
    The first priority is always handling . The traction issues can be addressed with suspension and tires, and since you like the way it currently handles, I would strongly recommend against going any longer than an additional 2" on the swingarm even though you are also extending the axle, and even 1 1/2" or 1 3/4" longer might be enough for your particular app . I guarantee you that 2" will make a day and night difference in how it handles . Even lengthening it by only 1" is enough to make a noticeable, but not drastic change in handling.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
    Jan 2013
    minnesota
    5,911
    12. Brakes. I want to either rebuild the master cylinders or use something from a newer-than-30-year-old machine that would work.
    There isn't any big improvement on brakes on those in the last 30 years so there is very little to no point at all in trying to redesign the wheel unless you are extremely unhappy with them . If you wanted a little more grip you might get it with different pads than you have been using . If you want it to stop using a lot less force/effort on the pedal and/or lever, installing smaller masters or larger volume calipers will do that but that will increase the amount of travel the lever or pedal operates over so it will be a trade off.
    Arizona
    843
    I'm running a 38 mm Keihin Air Striker with a reed spacer. The reed spacer improved the performance considerably. Some people dismiss them, but for this application it worked wonders. The intake manifold on the Z is small, so the spacer pulled the reeds away from the ports and added volume. I would definitely recommend giving one a try after you get the engine up and running. Finally, Greg prefers you call him direct rather than buy through ebay.
    Sep 2006
    Northwest Indiana
    1,893
    Brandonlowe2. I have a complete lower end that may interest you. It was a no expense spared
    build for a project Z I built. I changed course and never used it. I will sell at a very reasonable
    Cost ratio to what is invested.
    May 2016
    Georgia
    412
    Quote Originally Posted by tecat-z View Post
    PM sent to ya!
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    May 2016
    Georgia
    412
    The main thing I wan to accomplish with brakes is to have a parking brake and also be able to install a "blinking" brake light that turns on when I pull the front and/or rear brake. We do alot of night riding in the mountains and it would be a big help to have this feature. Also, because of the mountains, the parking brake would really nice.
    I know the brakes have nothing to do with replacing the calipers, but, I believe I will have to in order to get the parking brake set up
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    May 2016
    Georgia
    412
    Ok, it looks like I am going to be able to get the bottom end from "Tecat-Z" It looks really nice and is exactly what I want because it is an '85, which means 6 speed transmission!
Name:	2016-12-22 19.54.37.jpg
ID:	237966Click image for larger version.
Name:	2016-12-22 19.54.39.jpg
ID:	237967Click image for larger version.
Name:	2016-12-22 19.54.46.jpg
ID:	237968Click image for larger version.
Name:	2016-12-22 19.55.02.jpg
    Also, I have decided that I am going to deviate slightly from the original '85 1/2 color scheme. I know some people might not agree and probably would prefer to see me keep it OEM colors, but, I have thought about it and I want to make it "my own" So, unless I change my mind again, I am going to do the frame and nerf bars muscle car orange. The swingarm and skidplate will be white. The shock spring will be orange. The motor will stay black. The pipe will be chrome as well as the axle. The plastics will be Carbon Fiber. The seat will be mostly orange with some designs stitched in (by cosmic quads) possibly white and black stitched flames or something. Will put new Tri-Z decals on the carbon fiber plastics but will have the "Tri-" custom cut in white and the "Z" cut in orange. The rear wheel will be black with orange beadlocks and white hubs. The front wheel black with white hub. Also, I am working on customizing the front headlight shroud to accept two 12" LED light bars (stacked on top of each other) one which will be a spot and the other a flood (low and high beam) I am hoping that it turns out the way it is in my head.... then I just have to figure out how to make sure the stator can run the LED's and if not, figure out how to add a small battery.
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
    Mexico
    9,018
    You might want to confirm that. 1985's came with a 5 speed, but he could have put a 6 speed in it from a 1986.
    It sucks to get old
  15. #30
    May 2016
    Georgia
    412
    Sorry I said that wrong... the bottom end is in fact an '86 not an '85
    1985 Tri-Z
    1986 250sx
    1985 ATC70
    1985 ATC 200M
    - Brandon
