Thread: Tubes vs tubeless.. any advantages?
    Nov 2016
    Barkhamsted, CT
    18
    New to the whole ATC thing still, and I have a bad rim that a good tire is currently on, and a good rim I'm gone swap it to. Thing is, it's the split remand I think theres some kind of gasket in-between.. so I can do it the right way and replace that gasket and try and air up the tire, or just stuff a tube in there and call it OK. But.. wondering? Is there any advantage or disadvantage of using a tube vs not?
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Tire without a tube can be plugged or you can use fix-a-flat. If a tub is punctured; it is done. That being said, tubes can be used for old tires that have tread that will not hold air or have dry rot, but they do not replace a good tubeless tire. For a split tire, just order the large o-ring for the rim, I have used caulking, cut big chunks of rubber, but nothing will work as good as the original.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Exactly what he said. Always avoid using tubes. I have used tubes in dry rotted tires that still had good tread, but they are always a pain in the arse for multiple reasons.
    Sep 2013
    Southern Wisconsin
    24
    My 200x would constantly rip the stem off by twisting the time rim inside the tire. Best to buy a newer 1 piece rim or weld yours
    84-200x
    83-200x
    84-200es
    84-200es
    82-250r
    84-70
    84-125m
    83-200e
    85-350X
    83-185
    19??-110-never really looked at the year
    That's not previously owned..I ride them all every couple of months!!
    15-20 other parts and pieces machines that keep mine all running for cheap!!
    Jul 2016
    Kentucky
    61
    I've had good luck with tubes. Green slime even makes some that are pre-filled with goo that are amazing. Never had them in anything with enough torque to shear the stem. That'd be a problem
