85 ATC 200s. Rear pads have about half life left. Bought a new cable (rear hand brake) but the cable seems too long (double checked, its the correct cable). Any instructions out there on how to properly adjust? Problem with the rear brake up on the handle as well as foot. Does the rear piece that bolts next to the drum need to move down? Is it adjustable?? When i pull in the lever it only barely presses the pads. Cable is screwed in all the way on top and bottom
