I bought this 125 motor to put in a 70 frame. The left side cover was leaking oil so I pulled it off to make a new gasket and found metal shavings and wear marks inside the flywheel and around the entire outer surface of the stator. Is there anything I can check on before I call the seller and try to swap this motor for another?
