Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: New Member With Oil Plug Issue *help*
    May 2016
    OH Canada
    1,102
    I do a lot of these drain plug repairs threw my shop and this is the easiest and works very good .
    12m to 13m is the kit needed . The rubber plug will work but their a pain in the rear to get back out once installed .
    Neat kit. I have used Time Serts back in the day. Worked for a race shop for 5 years (cars). We had a complete kit of time serts. Never liked the heli coil. But that's me.
    6,788
    The kits are all over eBay . The most common size for atvs is the M13 , I use a lot of them .
    Here is a good deal on eBay .
    Quote Originally Posted by NeverLift View Post
    Who makes this kit? Where did you get it? I'd like to get one.
    Sent from my XT1080 using Tapatalk
    Dec 2015
    S.E. Louisiana
    28
    Here is the same kit on eBay that shortline10 mentioned but about $12.00 less. $28.02 includes shipping. Ordering one today.
    http://www.ebay.com/itm/24PC-OIL-PAN...435135&vxp=mtr
    Rick
    Jun 2016
    MN
    Update.....
    After letting the machine drain dry. I cleaned the sump with q-tips and break cleaner. Was about to do a retap however we noticed on the top side of the sump there is a pea size piece missing.
    Went the RTV route until spring time to weld in an aluminum rod and new tap
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Woodrow03 View Post
    As I was backing the oil plug out I could feel constant tension.
    It appears I pulled a helicoil out. Or heavy threads. Not sure. It stayed in tact and I was able to unthread it so that's what makes me think it is a helicoil.
    Put bolt back in. It threads but won't snug up....
    Update..... After letting the machine drain dry. I cleaned the sump with q-tips and break cleaner. Was about to do a retap however we noticed on the top side of the sump there is a pea size piece missing.
    It will likely leak and your drain plug might fall out while riding it . The rubber expansion plug I posted is likely a safer bet and less likely to leak if properly installed.
    You MUST disassemble the engine if you plan to weld, drill, and re-tap it . Also, If you disassemble it, I would simply put a time sert with a larger plug or big sert with the same size plug . Welding and using the aluminum for the threads again is not the best thing to do.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
