What's up 3ww I'm having problems with my shifter is not coming back and when I hold it up it's still in gear instead on neutral. Can anyone help? You can text me at(413)636-5884 Thanks
I would suggest editing your phone number out. Members here can help you through the site.
Sent from my SM-G935V using Tapatalk
Saying "it's the trikes fault" is like saying "guns kill people"
don't poke the bear... you'll get banned
I would suggest acually stating which machine you are inquiring about..![]()
83 KAWASAKI KLT200C
83 HONDA BIG RED 200E
84 HONDA BIG RED 200ES x2
85 HONDA 250SX
86 HONDA 125M
HEALD HAULER TRIKE W/DUMPBOX
Yes that too^
It's a big red 250 when I click down does not come back up and when I hold the shifter up it's supposed it stay in neutral but it stays in gear. Can anyone advise me in what direction to take? Thanks
Remove the left side motor cover and check the shift mech . Some thing is loose or broken .
Very common issue with that motor .
I will do that thanks for the help.
Let us know how it works out. I had one like that and I replaced my shift shaft assembly, only had to pull the side cover and drain oil first. If I'm not mistaken, this was more common on the 85 motors? Maybe it was the same as the 86/87 but I thought I've heard about it more on the 85's.
