Results 1 to 3 of 3
Thread: TRI Z correct compression tester & leakdown tester
    Dec 2013
    Coachella Valley, Calif
    124
    Just bought a old Tri Z, need to find out condition & tune up. 1st thing 1st. Compression & leakdown. (bear with me folks I'm budget restricted...lol)
    1st time trying this. I bought a inexpensive compression kit from HF. I did a test on the Tri Z and ir reads 90 lbs.?
    Now I know that would be considered very low...Mt question : Ive read on several vintage tuners websites thst a "specific" compression tester is required, with a valve in the end?? Is that true?
    The length oh the nipple on my tester is about 1/4" shorter than my spark plug. So volume wouldnt be the same.
    Yea I know its a HF tool, (but would it be that far off? ) From what I understand I want around 150LBS.
    Also can anyone recommend a CHEAP leakdown tester..that I can build or buy..that I can obtain Reliable readings from.
    Thanks!
    Sep 2005
    MICHIGAN
    2,027
    For leak down tester you could try to make your own:
    http://www.3wheelerworld.com/showthr...r-for-about-20
    86 T3
    84 T3
    86 KX250
    Jan 2017
    MI
    74
    Spray soapy water where the tool threads into the head and on the tool to make sure it doesn't leak. The compression tester has to have a schrader valve if the tool doesn't have one its useless thats with any compression tester..
    Does the engine run? If so I would think there is a problem with the tool.
    The compression tester sold at sears is a good one.
