Page 11 of 15 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 151 to 165 of 214
Thread: 1985 Honda 200X
  1. #151
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by KLT185 View Post
    So you didn't pull the shifter shaft just used a pick?
    Sent from my iPhone using Tapatalk Pro
    Yes...........on my Yamaha I just used a slightly curved pick and a small screwdriver. I didn't remove the shaft
    Edit.........don't forget a small amount of oil on the seal prior to installing
  2. #152
    May 2009
    S.E. Michigan
    1,251
    This is on ebay for $35.........I'm sure most here have seen it listed. I'm guessing after I get it I'll be at $550. Still fairly thrifty considering everything that's been done on it.
    I bought a 350x seat cover from that seller on e-bay. The material is great, the quality of the printing is great, but the installation is very tricky with pre-printed logos. What happened to me is that the "350x" curved downwards towards the back of the seat due to having to stretch the back enough in order to get rid of wrinkles. It didn't look horrible, but you'll need to spend some time with it (lots of temporary tacks) in order to keep the "200x" logo straight and even.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
  3. #153
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by wonderboy View Post
    Your right and that's been my fear ever since I recovered my "field find 350X". It only had the Honda logo in the back........nothing else and I could barely get that straight.
  4. #154
    May 2009
    S.E. Michigan
    1,251
    I did my own seat quite some time ago. I had really good luck stenciling the logos myself and using VHT Vinyl Die (in a spray can). I just wasn't crazy about the material I used back then (it was nice, but wasn't OEM).
    With the e-bay seat, I like the material and color. I contacted the seller and he said he could sell me the cover without the stenciling. So, I'd get the nice OEM style material, be able to install it without worry about keeping logos straight, THEN apply the Honda and 350X logo. It might be something to think about, depending on the level of effort you want to invest.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
  5. #155
    May 2015
    San Diego, CA
    1,800
    Thanks for sharing your experience. When I get to that point I may ask for some assistance with your techniques............... as it sounds like something I can do.
    Up until the 350X I never upholstered anything in my life. The video the cover came with made applying it seem easy but I found out otherwise.
    I usually leave things like this to the pro's but there's no room in my budget for professional upholstery services.
  6. #156
    Jul 2016
    Liberty NC
    20
    I ordered the same seat cover, had the same problem and it took 3 weeks to get here
  7. #157
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by 1969camaro View Post
    That's not bad.
    I did this one about a year ago for the first time......86 350X. It had no lettering to line up. Sometimes I feel part of the problem is the older foam was not adequate
    Sent from my SM-T900 using Tapatalk
  8. #158
    May 2015
    San Diego, CA
    1,800
    The slider came out nice. Ugly fork boot will get the wintergreen bath tomorrow.
    I will probably preload the springs up front about an inch. They are old and a little saggy but usable. I understand it will reduce travel by an inch under full compression but this will be fine.
  9. #159
    Jan 2013
    minnesota
    5,911
    No, it will not reduce travel by an inch.
    If they are too soft you can also use thicker oil and raise the oil level by 1/2" in addition to increasing the preload.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
  10. #160
    May 2015
    San Diego, CA
    1,800
    Thank you 468.
    Rebuilt the fork caps.......meaning new o rings and a cleaning. It's all the little things.
  11. #161
    May 2015
    San Diego, CA
    1,800
    The master is yucky. It worked but felt spongy and clumpy. In an effort to maintain my budget I'm going to reuse most of the items with the exception of the large o ring to the reservoir.............and a quick paint.
  12. #162
    May 2015
    San Diego, CA
    1,800
    Cleaned up the headlight and polished it the best I could. I had a good light to start with.
    Installed the bent headlight guard. I wasn't going to but I figured since I already painted it I might as well.
  13. #163
    May 2015
    San Diego, CA
    1,800
    Achtung !.......trade me for my 200S !.....Achtung .......i see nothing ......i hear nothing.....
    Souvenez-vous!!........what will Mrs. Glamy ride then?.........Souvenez-vous!!!........preservez la marriage!!........or she gets half ...........of..........da money............. da money is hers!!
  14. #164
    May 2015
    San Diego, CA
    1,800
    Although the throttle looked clean inside it was slow to swing and was clumped up with old hardened dirty grease. Cleaned all the internals and applied some new grease and........ bada boom bada bing........good as new.
    One problem I forsee is with the new.......more narrow bars......the front master looks as if it may not have enough space. May have to cut off that little lip to slide it over a quarter of an inch or whatever.
  15. #165
    May 2015
    San Diego, CA
    1,800
    Mounted the unfinished master to see if it will work. It's a little angled but should be fine even with the protector mounted. It's hard cleaning but a lot of the corrosion and what not comes off after an acid bath.
