Trying to rebuild my 86 250es carb and the last jet is almost stripped out. What should I do?
Sent from my HTC One M9 using Tapatalk
Heat it up with a butane torch and see if it will come out.
And for the love of all things holy, set that carb in some Berrymans chemdip for a couple days. It's pretty bad.
yeah i agree with yaegreb soak that carb down for a few days then should be good.
Should work just fine. Remember to remove all thing plastic or rubber from the carb body and bowl.
This is what it looked like before a can of carb cleaner. What a joke
Lps1 also works wonders! Spray some in the Jets and let them sit a bit, hopefully it will knock some of the Jets loose
Sent from my SM-G935T using Tapatalk
Heat didn't work so aed a t10 torx bit into the jet and backed it out with my drill. Worked like a charm.
