Results 16 to 30 of 62
Thread: 185s build (full suspension) - 2021 Update
    Dec 2014
    Lexington, KY
    117
    Looking good man keep it up I always love seeing a 185s being brought back to life.
    Quote Originally Posted by ZacH_GrifF View Post
    That's not my bike plevib. Hopper055 thank you, I actually found your thread after I posted the question, that thread helps a lot thanks. I'm actually looking to adapt a warrior 350 swingarm for my rear suspension I just need to know the carrier mount width at the end of the swingarm and the pivot tube diameter.
    I'll have to mesure the OD of the pivot tube for you. The carrier is stock so I beleve that you can use your current frame to find out the width. I'm excited to see how this comes out I have another 185s that I would love to suspend.
    1982 ATC185s
    1982 Suspended ATC185s
    1984 ATC70
    1984 ATC 250r
    19?? Motorcraft Three wheeler
    1974 Pacesetter 3
    1984 kawasaki 185
    1977 Atc 90
    1983 ATC 200x
    My suspended ATC185s build thread.
    http://www.3wheelerworld.com/showthr...s-Build-Thread
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    Thanks Hopper055, the pic below is the main measurement I need in addition to the pivot tube OD.
Name:	Warrior swigarm.JPG
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Motor is all torqued, lubed, primed, and painted.
ID:	240121Click image for larger version.
    3. 85 200m
    Dec 2014
    Lexington, KY
    117
    Sorry it took so long for my response. I just got a chance to take the suspended 185s to work to measure it. The od of the pivot tube is 28.6mm painted. I couldn't get a good angle for the other measurement. But like I said before it is the same as stock. My stock carrier bolts to it the same as the stock frame. If you still need that measurement for any reason just let me know. I still have the piece that I cut off my frame that I could measure for you I just have to find it.
    1982 ATC185s
    1984 ATC70
    1984 ATC 250r
    1974 Pacesetter 3
    1984 kawasaki 185
    1977 Atc 90
    1983 ATC 200x
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Thanks Hopper055, no need for anymore measurements, I'm pretty sure I'll be able to get it to work. Fixing to pick up a warrior swing arm here pretty soon. I'm determined now, so I'll make it work. Made a little more progress on the bike. Motor is in the frame now. Either, before the rebuild it was just wore out, or I'm just not used to the compression a 10.25:1 piston has. I'm glad I kept the decompression lever. I bought the aftermarket CDI not because I thought it was a better unit, I bought it because it had the pigtail and I wanted to run weatherpack connectors. I'm pretty sure all the 5 pin CDI's are the same, so I'm not worried about it. Since I'm making a new wiring harness I put new heat shrink on the stator/igniter wires. Also, I will not be running the mudbug tires, there just on there so I can roll it around. It will get turf tamers, or holeshots eventually.
ID:	240652Click image for larger version.
ID:	240653Click image for larger version.
ID:	240654Click image for larger version.
ID:	240655Click image for larger version.
ID:	240656Click image for larger version.
ID:	240657Click image for larger version.
ID:	240664Click image for larger version.
ID:	240658Click image for larger version.
ID:	240659Click image for larger version.
ID:	240660Click image for larger version.
ID:	240661Click image for larger version.
ID:	240662Click image for larger version.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    It runs!
    Got the motor cranked up last night and I'm very happy with the way it popped off and ran so good. Everything on the harness needed to make it run is hooked up, just gotta get a Kohler reg/rec and a master switch and I can hook up the lighting circuit. Put a bigger carb on it, because it was complete and it sorta fit. Figured it was gonna need to be rejetted, but surprisingly it ran great with open header and no air box/filter. I'm assuming it will need to be rejetted when I get a full exhaust and air box put on. Also, put the throttle setup off my parts yz250 on it and it worked, so I might run with it.
ID:	240794 Click image for larger version.
ID:	240795 Click image for larger version.
ID:	240796 Click image for larger version.
ID:	240797 Click image for larger version.
    Gonna try and adapt this sbc 350 motor mount for my swingarm mounts. Will probably have to beef it up just a little.
    Video of it running.
    https://www.youtube.com/watch?v=7YWn-bfEHHo
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Aight before I get to the suspension, here's a couple things here and there.
    New Uni Filter.
    PZ30 30mm (carb I'm running) vs original 24mm carb
    The stock air box-carb boot will fit on the pz30. I just put it in boiling water for a couple minutes and it let it stretch out enough to fit the carb.
    New 30mm intake manifold to match up to the pz30, I will eventually port the head to fit it.
    Don't have a picture yet because it's still in shipping, but I ordered a 200x DG RCM exhaust to use on it, so that will be added soon.
    Now the Best part, rear suspension!
    I ordered 90-04 Yamaha Warrior 350 swing arm to adapt to the bike, and it almost bolts onto the 185s carrier/axle. The top two bolt holes are a direct bolt on. The swing arm carrier mounts are about a 1/4" to 1/2" narrower than the 185s carrier is, so that will give me a little wiggle room to adjust left or right for chain alignment. The bottom two that are slotted don't quite match up, but there is enough room to drill new holes and run a bolt on chain-tensioner.
ID:	241187 Click image for larger version.
ID:	241188 Click image for larger version.
    As far as mounting it to the frame, I would love to fit it in between the motor and frame for strength but I just don't think there is enough room there, so it might have to be mounted outside the frame from the motor. I drew up the mounts I'm thinking of creating to use with it. The mounts will be 3/4" wide with two 1/8" plates and a sleeve welded between the two plates. The sleeve will be the old pivot tube, cut up, since I got a new one with the swing arm rebuild kit I got, so there won't be any slop.
    Depending on whether it gets mounted inside or outside the frame it will add 4"-6" to the wheelbase.
    I'm setting it up for 20" rear tires and a 23" front tire. Front tire will be a Kenda Front Max and I haven't decided on the rear yet, but it will be 20x10-9. I'm going to try and get the countershaft, pivot bolt, and axle in as straight of line as I can, accounting for sag due to rider weight.
    Not sure if I can use it yet but I have a 92 YZ250 rear shock I'd like to use since I had it on a parts bike and its basically free.
    If yall see any problems I may encounter or would like to make any suggestions, I'm all ears. I'm not gonna say I'm qualified to do this, but I do have a decent understanding, decent welding ability, and I'm currently going to MS State University for Civil Engineering, which has been tough but I'm enjoying it so far. Also, because of me going to school, it may be a little bit between post due to having a 3 hour drive between school and home on the weekends.
    3. 85 200m
    Scootertrash's Avatar
    In the sticks
    4,638
    Now you've given me another project to add to my list!
    Modifying suspension for a hard tail frame. No wonder I never get anything done!
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Been a busy Saturday
    Well I got started at 9:00 this morning and I got alot of progress done. Drilled the holes for the bottom swing arm bolts.
ID:	241287 Click image for larger version.
ID:	241288 Click image for larger version.
ID:	241289 Click image for larger version.
    Had to take one last pic for good times sake, haha.
    Had a little bit of an accident with the cut-off wheel, so just a reminder yall where your eye and hand protection.
    Subframe removed.
    Couldn't use the mounts I designed, so I made some pivot mounts out of the old axle carrier mounts.
    Mocked up.
    Tacked it in place where I thought it needed to be the first time but with the chain tight at full droop it had 2" of chain slop at 6" of suspension travel. So I cut the tacks and raised the pivot point 3/4", tacked it in place again, and it completely fixed the slop issue. From full droop to 6" of travel I have zero change in chain slop and the chain barely rest on the slider at full droop and clears it by 3/4"-1" at what I plan to be rider weight sag, around 3".
ID:	241296 Click image for larger version.
    Couldn't use the yz250 shock just way too long. So still looking for a shock to use.
    3. 85 200m
    In the sticks
    4,638
    You should make an independent thread about doing just the swing arm modifications/installation. Less stuff to sort thru to find the info in the future.
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Noted, I can make a new thread when I finish, just about the swingarm.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Little update, figured out how to make the yz shock work hopefully. Will be deleting the airbox and running a pod filter, it will allow me to use warrior 350 linkage and lean the shock forward like most bikes have it.
    Also, new DG exhaust came in.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    She's so long now, really wanting to get the 20 in tires for the rear, but these 25s show you just how much longer it is. The warrior 350 swingarm ended up adding 7 inches to the wheelbase. DG exhaust sounds great, still young dont care too much for quite bikes, didn't realize though, that the DG setup was basically a straight pipe with a resonator on it haha.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Little update, I got the warrior 350 linkage on and the yz shock bolted to it.
ID:	243605 Click image for larger version.
    On the to do list other than making it look pretty is
    1. Subframe braces.
    2. Larger gussets for the swingarm mounts.
    3. Make upper shock mount.
    4. Make front linkage mount.
    5. Get the carb to work with air box delete and new DG.
    6. Chain tensioner.
    3. 85 200m
  15. #30
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Got the linkage hooked up and will be making the upper shock mount tomorrow. Then chain tensioner, test ride, and million small things that every project has haha.
    Linkage mount mockup.
ID:	243905 Click image for larger version.
ID:	243906 Click image for larger version.
    How I setup my suspension.
    Mount welded on.
    Bike at full droop and then at linkage lock.
ID:	243910 Click image for larger version.
    The linkage allows for 8.5" of suspension cycle.
    3. 85 200m
