Results 46 to 60 of 62
Thread: 185s build (full suspension) - 2021 Update
  1. #46
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    Got the foot pegs cleaned up and swapped over. Painted the rear axle assembly and the swingarm today. Decided to make a spark arrestor for the DG since I ride in the National Forest near me. Hoping they don't pop me with a ticket since it doesn't have the usfs stamp haha.
ID:	267228 Click image for larger version.
ID:	267230 Click image for larger version.
ID:	267232 Click image for larger version.
ID:	267234 Click image for larger version.
ID:	267235 Click image for larger version.
ID:	267236 Click image for larger version.
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
  2. #47
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Got the frame painted and assembled and everything back together. I ordered a different needle from jetsrus and it’s perfect. Carb is completely tuned now. Running a 110 main jet, 36Q needle on the second leanest clip, and a 38 slow jet. Ended up going with a 3rd gen R fender for the front. I’ll buy a new rear 185s fender at some point to make it look all fresh. Bike is coming along nicely. I want a front max for the front tire but absolutely nobody has one that isn’t on back order so not sure what front tire I’ll go with.
ID:	267335 Click image for larger version.
    3. 85 200m
  3. #48
    6,807
    Looks great !
  4. #49
    2,591
    I agree. It's looking really good. Now you just have to figure out something to cover up the space between the forks (side ti side) and the triples (up and down). You could get real crazy and mount a radiator there so it looks more like a first gen Tecate.
  5. #50
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Thanks guys. I kinda think I want to fab up an old school looking headlight cage for dual round lights. Like Baja style. Or I might just do a number plate or a second gen headlight setup. Not completely sure. It’d funny you mention the radiator because I have a 92 yz 250 engine that I will put in there if this motor ever dies and I figured I’d put a tecate style rad there if I ever went that route
    3. 85 200m
  6. #51
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Fabbed up a quick little mount out of some flat steel to use a 200m headlight I had without modifying the headlight or the triple cuz I just needed a headlight option for a ride I went on. This will more than likely be temporary.
ID:	267472 Click image for larger version.
    I had a friend with some Kenda Gecko paddle tires so I elected to borrow them for the ride I went on this weekend. The place was a big sand pit and had several hill climbs and whoop sections. With the swing arm being so long the bike did awesome on the hill climbs although it could use some more power. I was able to make up for it with speed though. The R and yz suspension setup I have soaked up the whoops great. That was prolly the most fun I have had on a bike to date.
ID:	267474 Click image for larger version.
    Overall I am very happy with the bike and how everything is working. The sand did do a number on my chain and it made me realize I need to add a guide in front of the sprocket so I bought a stock banshee/warrior chain guide and will welding a mount on the swingarm for it shortly. With the chain stretching from getting worn by the sand (i should have oiled it) it was starting to slap the bottom of the swingarm so I am gonna put a lighter spring on my tensioner and in conjunction with the guide it should ride further away from the swingarm.
    3. 85 200m
  7. #52
    Nov 2019
    Florida
    1,051
    Nice work around on the light, round the corners and paint it black to look factory
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
  8. #53
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Just a little update. I ended up finding a Kenda Front Max to replace the front tire. Nothing really else done to it lately. Just been enjoying it and riding it a bunch. So glad I tuned it correctly with an AFR gauge it starts easily and runs so good. The cold weather hasn't affected its ability to start and run at all.
    3. 85 200m
  9. #54
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Finally found a new, exact fit, aftermarket front brake caliper for the bike. Was on Ebay and noticed someone was selling 81-84 250r calipers listed as new and snagged one immediately. Doesn't come with the caliper bracket but luckily I already had one from an OEM used caliper I bought but ended up being seized up and useless. The listing showed it was black but it showed up as silver which is a bonus cuz I wanted silver anyways. Its nice to finally have working brakes front and rear.
    Went with a 32" steel braided brake line from Streamline and a Yamaha grizzly/kodiak right hand brake master which also comes with a brake switch so I can add brake lights when I get to that point. It stops great now and I can quit using my rear brakes as much haha.
ID:	268939 Click image for larger version.
ID:	268940 Click image for larger version.
ID:	268941 Click image for larger version.
ID:	268942 Click image for larger version.
    3. 85 200m
  10. #55
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Just a little update. Haven’t done much to it but ride it haha. Ended up laying it over and cracking the fender at the dunes one day so I Ritchie’s that with zip ties. Not really worried about it the fender was dry rotted real bad and I planned on getting another Maier fender eventually. They want $300 for a rear fender now, ugh. Got tired of looking at the “temporary” headlight bracket I made rusting away so I cleaned it up with a wire wheel and rounded the corners off. Hit those, the headlight mounts, and the gas cap with some black chassis epoxy. I’d like to make a better light setup but don’t have a lot of time these days haha.
    3. 85 200m
  11. #56
    2,591
    It looks great. How's the ride?
  12. #57
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    It’s rides really good. The yz shock really needs a rebuild so it’s a little floaty in the back. I rode 11 miles today and my back isn’t sore at all which is what the intended goal was. To have a bike that I can trail ride all day and not be all stove up afterwards but still handle decently well and it handles really well
    3. 85 200m
  13. #58
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Noticed yesterday my turning radius going left was way worse than turning right so I pulled the front end off today and made some adjustments to the steering stops. I had like a 1” gap between the tank and fork tube on one side and 1/2” on the other side. Not sure how I didn’t see that when I made the stops. Got it as close to the tank as I’m comfortable with. Turns much, much tighter now. Very happy
    3. 85 200m
  14. #59
    2,591
    That clearance look just about perfect to me.
  15. #60
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Hey guys, recently got a GoPro and decided to take a stroll through the neighborhood with the 185s to test out the mount and positioning. I threw it on YouTube if anyone cares to see/hear the bike in action. I am wearing a helmet.
    https://youtu.be/AC8JQUl-6Tg
    3. 85 200m
